Introducción
Below is a list of instructions on replacing and cleaning a Nokia 6133 keypad.
Partes
No se requieren partes.
Remove the back cover of your cell phone by applying slight pressure with your thumb and pushing up towards the top of the phone. Lift off back cover.
  • Remove the back cover of your cell phone by applying slight pressure with your thumb and pushing up towards the top of the phone.
  • Lift off back cover.
Agregar Comentario
Use your index finger to first push down and then lift up the battery as shown. Remove battery from cell phone. Remove battery from cell phone.
  • Use your index finger to first push down and then lift up the battery as shown.
  • Remove battery from cell phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Unscrew two T5 torx screws easily visible on the back side of the cell phone Screws: 7.8mm
  • Unscrew two T5 torx screws easily visible on the back side of the cell phone
    • Screws: 7.8mm
  • Once screw are removed, the phone will separate easily into two pieces connected by a flexible wire strip.
    • Be sure to not lose or disconnect the indicated piece that the screw mounts to. It is spring loaded and is very dificult to reattach.
Agregar Comentario
Use an iPod opening tool to gently pry open the back case as indicated in the picture. Work your way down the side of the phone starting from the top down to the bottom. (Use multiple prying tools if necessary) REPEAT on both sides, and be careful not to stab the circuitry with the tools.
  • Use an iPod opening tool to gently pry open the back case as indicated in the picture.
    • Work your way down the side of the phone starting from the top down to the bottom. (Use multiple prying tools if necessary)
  • REPEAT on both sides, and be careful not to stab the circuitry with the tools.
Agregar Comentario
Gently pull the phone apart and the flexible wire should detach from its connection as shown. If not, lift up on the black tab within the left box in the picture. With the front half of the phone, push the keypad towards the removed portion of the phone.
  • Gently pull the phone apart and the flexible wire should detach from its connection as shown.
    • If not, lift up on the black tab within the left box in the picture.
  • With the front half of the phone, push the keypad towards the removed portion of the phone.
    • To clean, use a damp cloth with water.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Vincent Benvin
Miembro Desde 19/04/10
121 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 23-82, Johann Spring 2010 Miembro de Cal Poly, Team 23-82, Johann Spring 2010
CPSU-JOHANN-S10S23G82
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,861
