Introducción
Gather tools needed. Have a small tray or container on hand to hold screws and cell phone parts as you disassemble and reassemble the Nokia 6061.
Gather the necessary tools: T6 Torx screwdriver Plastic opening tool
  • Gather the necessary tools:
  • T6 Torx screwdriver
  • Plastic opening tool
  • Small flathead screwdriver
Agregar Comentario
This guide will show you how to replace the LCD—after it's been dropped one too many times.
  • This guide will show you how to replace the LCD—after it's been dropped one too many times.
Agregar Comentario
Using a 2.0 flathead screwdriver, pry open and remove the black, plastic strip (beneath the screen) to reveal the 2 screws holding the screen in place.
  • Using a 2.0 flathead screwdriver, pry open and remove the black, plastic strip (beneath the screen) to reveal the 2 screws holding the screen in place.
Agregar Comentario
Remove the two T6 Torx screws from the base of the display.
  • Remove the two T6 Torx screws from the base of the display.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Once the screws are removed, flip the phone shut. Insert the plastic opening tool at the position indicated and pry along the seam between the front cover and display. Continue prying along the perimeter of the front cover until it is free from the phone.
  • Once the screws are removed, flip the phone shut.
  • Insert the plastic opening tool at the position indicated and pry along the seam between the front cover and display.
  • Continue prying along the perimeter of the front cover until it is free from the phone.
Agregar Comentario
Use a plastic opening tool to pry the LCD circuit board up and out of the phone. Be careful not to damage the circuit board.
  • Use a plastic opening tool to pry the LCD circuit board up and out of the phone.
  • Be careful not to damage the circuit board.
  • Flip the display up and over to expose its ribbon cable connector.
Agregar Comentario
Use a plastic opening tool to gently pry the LCD ribbon cable connector up out its socket on the LCD circuit board. The other two photos show the male and female sides of the small green connector. Make sure they snap together tightly when the new display is attached. The other two photos show the male and female sides of the small green connector. Make sure they snap together tightly when the new display is attached.
  • Use a plastic opening tool to gently pry the LCD ribbon cable connector up out its socket on the LCD circuit board.
  • The other two photos show the male and female sides of the small green connector. Make sure they snap together tightly when the new display is attached.
Agregar Comentario
To reassemble your phone, reattach the display to the phone by reconnecting the display ribbon cable. Place the screen assembly back into the front case of the phone.
  • To reassemble your phone, reattach the display to the phone by reconnecting the display ribbon cable. Place the screen assembly back into the front case of the phone.
Agregar Comentario
Replace the phone cover by applying pressure until a click is heard.
  • Replace the phone cover by applying pressure until a click is heard.
Agregar Comentario
With the cover reattached, flip the phone into the open position and replace the screws removed in step 3.  The screw-holes are indicated in the photo.
  • With the cover reattached, flip the phone into the open position and replace the screws removed in step 3. The screw-holes are indicated in the photo.
  • Replace the black, plastic strip by applying pressure until the strip audibly clicks into place.
Agregar Comentario
Linea de Meta
rosin7
Miembro Desde 14/02/13
55 Reputación
4 Guías creadas
Equipo
Ohio State, Team 1-3, Buehl Spring 2013 Miembro de Ohio State, Team 1-3, Buehl Spring 2013
OSU-BUEHL-S13S1G3
4 Miembros
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 737
