Introducción
Replacing LCD Screen.
Partes
No se requieren partes.
Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone. Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone. Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
  • Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
Agregar Comentario
Use your fingernail and gently pull the the bottom of the battery up. Lift out battery and remove. Lift out battery and remove.
  • Use your fingernail and gently pull the the bottom of the battery up.
  • Lift out battery and remove.
Agregar Comentario
Use your fingernail to lift the metal cage up. Remove SIM card. Remove SIM card.
  • Use your fingernail to lift the metal cage up.
  • Remove SIM card.
Agregar Comentario
Close the metal cage.
  • Close the metal cage.
Agregar Comentario
Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen. Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen. Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen.
  • Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen.
Agregar Comentario
After removing the top cover, turn the phone over so the screen is facing upwards. After removing the top cover, turn the phone over so the screen is facing upwards.
  • After removing the top cover, turn the phone over so the screen is facing upwards.
Agregar Comentario
Lift the front off the phone by pulling above the arrows. Lift the front off the phone by pulling above the arrows. Lift the front off the phone by pulling above the arrows.
  • Lift the front off the phone by pulling above the arrows.
Agregar Comentario
Remove the six screws with a T-6 Torx screwdriver. Remove the six screws with a T-6 Torx screwdriver. Remove the six screws with a T-6 Torx screwdriver.
  • Remove the six screws with a T-6 Torx screwdriver.
Agregar Comentario
Gently lift the top of the screen up. Be cautious of loose parts. Be cautious of loose parts.
  • Gently lift the top of the screen up.
  • Be cautious of loose parts.
Agregar Comentario
Gently pull up on the grey plastic tab. Gently pull up on the grey plastic tab. Gently pull up on the grey plastic tab.
  • Gently pull up on the grey plastic tab.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 23-63, Johann Spring 2010 Miembro de Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Miembros
17 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 13
Todo El Tiempo: 6,283
