Introducción
Use this guide to remove and replace the Nokia 6010's keypad.
Partes
No se requieren partes.
Press the small tab on the bottom of the back of the phone. Push the back case upward towards the power button. The back case will then pop off. It requires some force, so be careful.
  • Press the small tab on the bottom of the back of the phone.
  • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
Agregar Comentario
Lift the battery near the bottom and pry up. Lift the battery near the bottom and pry up.
  • Lift the battery near the bottom and pry up.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
With one hand, press the ridged tab near the visible side of the SIM card.
  • With one hand, press the ridged tab near the visible side of the SIM card.
  • Slide the card out with your other hand.
Agregar Comentario
Grip the phone on either the sides, the top, or the bottom. Pull the front case away from the rest of the phone.
  • Grip the phone on either the sides, the top, or the bottom.
  • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
Agregar Comentario
Lift the keypad away from the body of the phone.
  • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Nicholas Hanne
Miembro Desde 20/01/10
44 Reputación
16 Guías creadas
Equipo
Cal Poly, Team 14-45, Regan Winter 2010 Miembro de Cal Poly, Team 14-45, Regan Winter 2010
CPSU-REGAN-W10S14G45
5 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,905
