Saltar al contenido principal
Nokia 6010 Charger Connector Replacement
Qué necesitas
  1. Nokia 6010 Charger Connector Replacement, Battery: paso 1, imagen 1 de 3 Nokia 6010 Charger Connector Replacement, Battery: paso 1, imagen 2 de 3 Nokia 6010 Charger Connector Replacement, Battery: paso 1, imagen 3 de 3
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
  2. Nokia 6010 Charger Connector Replacement: paso 2, imagen 1 de 2 Nokia 6010 Charger Connector Replacement: paso 2, imagen 2 de 2
    • Lift the battery near the bottom and pry up.
  3. Nokia 6010 Charger Connector Replacement, SIM Card: paso 3, imagen 1 de 1
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
  4. Nokia 6010 Charger Connector Replacement, Keypad: paso 4, imagen 1 de 2 Nokia 6010 Charger Connector Replacement, Keypad: paso 4, imagen 2 de 2
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
  5. Nokia 6010 Charger Connector Replacement: paso 5, imagen 1 de 1
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
  6. Nokia 6010 Charger Connector Replacement, LCD Screen and Speaker: paso 6, imagen 1 de 2 Nokia 6010 Charger Connector Replacement, LCD Screen and Speaker: paso 6, imagen 2 de 2
    • Remove the six screws around the front of the phone body with a T6 screwdriver.
  7. Nokia 6010 Charger Connector Replacement: paso 7, imagen 1 de 3 Nokia 6010 Charger Connector Replacement: paso 7, imagen 2 de 3 Nokia 6010 Charger Connector Replacement: paso 7, imagen 3 de 3
    • Insert your finger underneath the speaker piece and pry away from the phone body.
    • The plastic layer containing the LCD screen and speaker takes some force to remove.
    • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
    • The LCD and the speaker are attached to the same piece and must be replaced together.
  8. Nokia 6010 Charger Connector Replacement, Logic Board: paso 8, imagen 1 de 2 Nokia 6010 Charger Connector Replacement, Logic Board: paso 8, imagen 2 de 2
    • Slide the rubber power button away from the body of the phone.
    • The power button is the rubber piece on the top of the phone.
  9. Nokia 6010 Charger Connector Replacement: paso 9, imagen 1 de 3 Nokia 6010 Charger Connector Replacement: paso 9, imagen 2 de 3 Nokia 6010 Charger Connector Replacement: paso 9, imagen 3 de 3
    • Insert a finger between the phone body and logic board.
    • The logic board is the green plastic piece with circuitry attached.
    • Pull the board away gently.
    • The board is delicate and contains electronic parts. Be careful while removing it.
  10. Nokia 6010 Charger Connector Replacement, Charger Connector: paso 10, imagen 1 de 3 Nokia 6010 Charger Connector Replacement, Charger Connector: paso 10, imagen 2 de 3 Nokia 6010 Charger Connector Replacement, Charger Connector: paso 10, imagen 3 de 3
    • Insert a spudger tool between the phone casing and the charger connector.
    • Pry the key away from the phone gently.
    • Be careful not to bend the metal leads while handling the power key.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 14-45, Regan Winter 2010 Miembro de Cal Poly, Team 14-45, Regan Winter 2010
CPSU-REGAN-W10S14G45
5 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 3,990
