Introducción
This guide describes how to replace the SD card of the Nokia 3300B.
Herramientas
No se requieren herramientas.
Partes
No se requieren partes.
Flip the Nokia 3300B over with the back-side facing towards you. Gently press the button on the back of the battery cover to release the cover and slide up.
  • Flip the Nokia 3300B over with the back-side facing towards you.
  • Gently press the button on the back of the battery cover to release the cover and slide up.
Agregar Comentario
Lift the battery out of the back of the phone. It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
  • Lift the battery out of the back of the phone.
  • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
Agregar Comentario
Using your finger, or a pair of tweezers, press down on the tab below the SD card. The card will pop out of its case.  Remove the card. When placing the new SD card in the slot, it should "pop" in.
  • Using your finger, or a pair of tweezers, press down on the tab below the SD card.
  • The card will pop out of its case. Remove the card.
  • When placing the new SD card in the slot, it should "pop" in.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
George
Miembro Desde 13/04/10
91 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 18-65, Johann Spring 2010 Miembro de Cal Poly, Team 18-65, Johann Spring 2010
CPSU-JOHANN-S10S18G65
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,447
