Introducción
The LCD is difficult to get to and the guide requires a moderate amount of work. Tiny parts require patience during disassembly.
Partes
No se requieren partes.
Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone.
  • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
Agregar Comentario
Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out.  This can be done with your finger-nail or a prying tool.
  • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
Agregar Comentario
Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Once the cover plate has been removed, the keypad should easily pop out.
  • Once the cover plate has been removed, the keypad should easily pop out.
Agregar Comentario
Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone. Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone.
  • Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone.
Agregar Comentario
Once the screws have been removed, the front plate of the phone should be removed, exposing the inside electronic components of the phone.
  • Once the screws have been removed, the front plate of the phone should be removed, exposing the inside electronic components of the phone.
Agregar Comentario
Take out the cell phone electronic board
  • Take out the cell phone electronic board
Agregar Comentario
The LCD screen can now be removed from the body of the phone.
  • The LCD screen can now be removed from the body of the phone.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Pierre Tong
Miembro Desde 11/03/13
44 Reputación
8 Guías creadas
Equipo
Clemson, Team 13-2, Benson Spring 2013 Miembro de Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 9
Todo El Tiempo: 905
