Introducción
The keypad is fairly easy to retrieve and it is not actually secured by any piece of the phone other than the cover plate. When replacing the keypad, make sure it is oriented properly because it tends to slide around.
Herramientas
No se requieren herramientas.
Partes
No se requieren partes.
Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone.
  • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
Agregar Comentario
Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out.  This can be done with your finger-nail or a prying tool.
  • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
Agregar Comentario
Once the cover plate has been removed, the existing keypad should be easily removed.
  • Once the cover plate has been removed, the existing keypad should be easily removed.
  • To install a new keypad, simply place the new keypad in the same place where the old keypad was.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Pierre Tong
Miembro Desde 11/03/13
44 Reputación
8 Guías creadas
Equipo
Clemson, Team 13-2, Benson Spring 2013 Miembro de Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 9
Todo El Tiempo: 475
