Introducción
In this guide, we outline how to unscrew and remove the front case from the Nokia 2630b. This grants access to the LCD screen cover and the keyboard.
Partes
No se requieren partes.
Press the release buttons located on either side of the battery cover Pull the battery cover away from the phone
  • Press the release buttons located on either side of the battery cover
  • Pull the battery cover away from the phone
Agregar Comentario
Gently pull the battery out of the phone with your fingers Gently pull the battery out of the phone with your fingers
  • Gently pull the battery out of the phone with your fingers
Agregar Comentario
Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
  • Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
    • The T5 bit has a star shaped end and has "T5" engraved on the side of the bit for easy identification
  • NOTE: Keep the screws in a safe place while you continue working.
Agregar Comentario
Separate the front case from the back case using the iPod opener NOTE: The keypad is a loose piece and may fall out NOTE: The keypad is a loose piece and may fall out
  • Separate the front case from the back case using the iPod opener
  • NOTE: The keypad is a loose piece and may fall out
Agregar Comentario
Remove screws using the same T5 screw bit to release the computer chip from the case
  • Remove screws using the same T5 screw bit to release the computer chip from the case
Agregar Comentario
Carefully lift the black frame off the screen with your fingers
  • Carefully lift the black frame off the screen with your fingers
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Carefully remove the computer chip and screen out of the black case with your fingers
  • Carefully remove the computer chip and screen out of the black case with your fingers
Agregar Comentario
The screen is attached to the motherboard by an orange ribbon Carefully detach the ribbon from the motherboard using your fingers
  • The screen is attached to the motherboard by an orange ribbon
  • Carefully detach the ribbon from the motherboard using your fingers
Agregar Comentario
Reattach new screen by connecting the orange ribbon to the computer chip
  • Reattach new screen by connecting the orange ribbon to the computer chip
Agregar Comentario
Place computer chip and screen back into black case Place computer chip and screen back into black case
  • Place computer chip and screen back into black case
Agregar Comentario
Place black frame back over screen
  • Place black frame back over screen
Agregar Comentario
Carefully place keypad back in place Carefully place keypad back in place
  • Carefully place keypad back in place
Agregar Comentario
Snap the front case back in place with the bottom case with your fingers Snap the front case back in place with the bottom case with your fingers
  • Snap the front case back in place with the bottom case with your fingers
Agregar Comentario
Reassemble screws with microscrewdriver
  • Reassemble screws with microscrewdriver
Agregar Comentario
Slide battery back into place
  • Slide battery back into place
Agregar Comentario
Snap battery cover back into place
  • Snap battery cover back into place
Agregar Comentario
Conclusión
To reassemble your device, follow these instructions in reverse order. Make sure to snap the new screen / front case securely into place.
Eric
Miembro Desde 07/04/11
51 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 9-61, Walters Spring 2011 Miembro de Cal Poly, Team 9-61, Walters Spring 2011
CPSU-WALTERS-S11S9G61
5 Miembros
5 Guías creadas
Great guide :-) I have a Nokia 2630 too and people can no longer hear me on calls, even though I can hear them. Do you know what could be wrong? Do you think this is something I could fix myself? Thanks!
jfg - Contestar
You could try getting a neodymium magnet and run it across the earpiece grill. In my father's case, a lot of metal powder was in there, pressing in the speaker membrane; the alternative is cleaning it (which does require opening the phone using Eric's very nice guide). The alternative to those is ordering an earpiece online - but usually those are really bad quality, so trying to fix the original one would be advisable
Darie H -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 3,564
