Introducción
After you have successfully completed the faceplate and circuit board removal guide this guide will show you how to replace the speaker
Partes
No se requieren partes.
Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off. Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off. Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
Agregar Comentario
Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone. Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone. Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
Agregar Comentario
Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger. After removal, lower the metal sim card holder into its original position. After removal, lower the metal sim card holder into its original position.
  • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
  • After removal, lower the metal sim card holder into its original position.
Agregar Comentario
Insert the plastic opening tool into the crack between the front and back panels. Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  • Insert the plastic opening tool into the crack between the front and back panels.
  • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
Agregar Comentario
Lift the bottom of the front cover away from the phone. Continue lifting until the top of the front cover is fully removed from the phone.
  • Lift the bottom of the front cover away from the phone.
  • Continue lifting until the top of the front cover is fully removed from the phone.
  • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
Agregar Comentario
Use the Torx screwdriver with the T6 attachmet  to remove the 6 .4 mm screws around the outside of the circuit board.
  • Use the Torx screwdriver with the T6 attachmet to remove the 6 .4 mm screws around the outside of the circuit board.
  • Note: Removing the 4 T6 screws around the screen will loosen it, so don't worry if the screen also separates from the circuit board.
Agregar Comentario
Lift the circuit board out of the back cover. Lift the circuit board out of the back cover. Lift the circuit board out of the back cover.
  • Lift the circuit board out of the back cover.
Agregar Comentario
Using the plastic opening tool, gently pry the speaker out of its slot in the back cover of the phone. Note: The easiest way to remove the speaker is to insert the plastic opening tool in the upper right corner of the speaker. Note: The easiest way to remove the speaker is to insert the plastic opening tool in the upper right corner of the speaker.
  • Using the plastic opening tool, gently pry the speaker out of its slot in the back cover of the phone.
  • Note: The easiest way to remove the speaker is to insert the plastic opening tool in the upper right corner of the speaker.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 7-52, Amido Fall 2010 Miembro de Cal Poly, Team 7-52, Amido Fall 2010
CPSU-AMIDO-F10S7G52
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 2,432
