Partes
No se requieren partes.
Be sure cell phone is off before you begin to disassemble the phone. Press the button on the bottom of the back of the cell phone. Slide rear panel down and remove  it.
  • Be sure cell phone is off before you begin to disassemble the phone.
  • Press the button on the bottom of the back of the cell phone.
  • Slide rear panel down and remove it.
Agregar Comentario
Using your fingernail, pry the back of the battery upwards and pull out. Using your fingernail, pry the back of the battery upwards and pull out. Using your fingernail, pry the back of the battery upwards and pull out.
  • Using your fingernail, pry the back of the battery upwards and pull out.
Agregar Comentario
Insert the plastic opening tool under the faceplate. Separate the faceplate from main body by twisting the prying tool with some force. The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  • Insert the plastic opening tool under the faceplate.
  • Separate the faceplate from main body by twisting the prying tool with some force.
  • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
With the faceplate removed, simply peel off rubber key pad and remove. With the faceplate removed, simply peel off rubber key pad and remove. With the faceplate removed, simply peel off rubber key pad and remove.
  • With the faceplate removed, simply peel off rubber key pad and remove.
Agregar Comentario
Locate and remove the six screws on the front of the phone using a T6 Torx. All 6 screws are 6.9mm long. All 6 screws are 6.9mm long.
  • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
Agregar Comentario
After removing screws, lift the motherboard assembly straight off the cell phone body. After removing screws, lift the motherboard assembly straight off the cell phone body. After removing screws, lift the motherboard assembly straight off the cell phone body.
  • After removing screws, lift the motherboard assembly straight off the cell phone body.
Agregar Comentario
Locate the two plastic LCD unit hooks. Pry hooks outward. Pry hooks outward.
  • Locate the two plastic LCD unit hooks.
  • Pry hooks outward.
Agregar Comentario
Gently pull LCD unit away from the logic board. Be careful not to damage the connection on the top, right hand side of the logic board. Be careful not to damage the connection on the top, right hand side of the logic board.
  • Gently pull LCD unit away from the logic board.
    • Be careful not to damage the connection on the top, right hand side of the logic board.
Agregar Comentario
With the LCD unit removed, gently press out the speaker with a non-metallic pointed object. With the LCD unit removed, gently press out the speaker with a non-metallic pointed object. With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
  • With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 20-8, Maness Fall 2010 Miembro de Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Miembros
28 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 186
