Introducción
To replace the motherboard, phone disassembly is required.
Partes
No se requieren partes.
To prevent shock, press down on the power button located on the top of the phone until the phone shuts off. Press down on the small gray button located on the back of the phone. Slide the back plate down and off.
  • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
  • Press down on the small gray button located on the back of the phone.
  • Slide the back plate down and off.
Agregar Comentario
To remove the battery, begin by holding the phone sideways. Then, insert your thumb in the groove below the battery and push the battery up and out.
  • To remove the battery, begin by holding the phone sideways.
  • Then, insert your thumb in the groove below the battery and push the battery up and out.
Agregar Comentario
Locate the spudger. A photo of the correct spudger is provided to the left. Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate. Insert the spudger into each square hole and push up to detach the face plate.
  • Locate the spudger. A photo of the correct spudger is provided to the left.
  • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
  • Insert the spudger into each square hole and push up to detach the face plate.
Agregar Comentario
Note: The keypad will be loose and may fall off during this step. Pull the face plate up and off of the phone.
  • Note: The keypad will be loose and may fall off during this step.
  • Pull the face plate up and off of the phone.
  • To remove the keypad, simply lift it off the phone.
Agregar Comentario
Locate the 6 screws on the metallic sheet that previously held the keypad. (This sheet, shown in the pictures, is the top side of the motherboard). Note: 2 of the screws are on the bottom corners, 2 are on the right and left edges of the phone below the screen, and 2 are on the very top corners of the phone, above the screen.
  • Locate the 6 screws on the metallic sheet that previously held the keypad. (This sheet, shown in the pictures, is the top side of the motherboard).
  • Note: 2 of the screws are on the bottom corners, 2 are on the right and left edges of the phone below the screen, and 2 are on the very top corners of the phone, above the screen.
  • Warning: The middle two screws are attached to the base of the phone with two black plastic rings. Use tweezers to remove the screws carefully to avoid breaking the plastic rings
  • Use a size T6 Torx screwdriver to remove each of these 6 screws.
Agregar Comentario
To remove the motherboard, lift it up and off the phone. Note: The screen will still be attached to the motherboard. Note: The screen will still be attached to the motherboard.
  • To remove the motherboard, lift it up and off the phone.
  • Note: The screen will still be attached to the motherboard.
Agregar Comentario
Conclusión
Shane
Miembro Desde 30/09/10
56 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 14-38, Forte Fall 2010 Miembro de Cal Poly, Team 14-38, Forte Fall 2010
CPSU-FORTE-F10S14G38
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 2,766
