Introducción
Use this guide to remove the outer case of the Nintendo Wii U and gain access to the DVD drive.
With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
  • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
Agregar Comentario
Rotate the console 180 degrees so that the exhaust vents are facing you.
  • Rotate the console 180 degrees so that the exhaust vents are facing you.
  • Remove the two 7.1mm Phillips #00 screws.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it. On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
  • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
Agregar Comentario
On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
  • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
Agregar Comentario
On the back of the console, lift up and release the main top cover. On the back of the console, lift up and release the main top cover. On the back of the console, lift up and release the main top cover.
  • On the back of the console, lift up and release the main top cover.
The front portion of the side of the cover with the vents was kind of stuck on mine. There’s a little rubber piece in there that was the cause of this. But that same rubber piece also makes up the little handle-shaped nub that sticks out of the side there. (There’s also one at the back of the same side, but that one didn’t stick for me.) Lifting also using the little handle made it easy to remove the cover.
Nicholas Halderman - Contestar
Conclusión
13 personas más completaron esta guía.
Kim Arre
Miembro Desde 11/01/13
2,953 Reputación
18 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
114 Miembros
5,912 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 7
Últimos 7 Días: 52
Últimos 30 Días: 214
Todo El Tiempo: 14,588
