Saltar al contenido principal
Nintendo Wii Remote Speaker Replacement
Qué necesitas
  1. Nintendo Wii Remote Speaker Replacement, Front Cover Plate and Batteries: paso 1, imagen 1 de 2 Nintendo Wii Remote Speaker Replacement, Front Cover Plate and Batteries: paso 1, imagen 2 de 2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Nintendo Wii Remote Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Speaker Replacement: paso 3, imagen 1 de 1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Speaker Replacement: paso 4, imagen 1 de 2 Nintendo Wii Remote Speaker Replacement: paso 4, imagen 2 de 2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
  5. Nintendo Wii Remote Speaker Replacement, Speaker: paso 5, imagen 1 de 3 Nintendo Wii Remote Speaker Replacement, Speaker: paso 5, imagen 2 de 3 Nintendo Wii Remote Speaker Replacement, Speaker: paso 5, imagen 3 de 3
    • Place the plastic opening tool between the edge of the speaker and the wii remote.
    • Gently lift the speaker out of the body of the Wii remote.
Conclusión
Una persona más ha completado esta guía.
Emily
Miembro Desde 04/14/13
1,524 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 3-44, Amido Spring 2013 Miembro de Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Miembros
26 Guías creadas
Un comentario
Thank you, u help me to fix it.
joon lew - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 26
Ultimos 30 días: 81
Todo El Tiempo: 6,743
