Introducción
The Z button is located above the right trigger but functions as a button.
Partes
No se requieren partes.
Place the controller (buttons down) on a solid surface.
  • Place the controller (buttons down) on a solid surface.
  • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Gently lift the back panel up, separating it from the front panel.
  • Gently lift the back panel up, separating it from the front panel.
  • Some of the buttons may fall out if they are knocked around.
Agregar Comentario
Grab the Z-button by the peg with tweezers and lift it out of the controller. During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  • Grab the Z-button by the peg with tweezers and lift it out of the controller.
  • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Sean Michel
Miembro Desde 14/01/13
1,229 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 19-44, Regan Winter 2013 Miembro de Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Miembros
16 Guías creadas
My z button presses down and makes the click, but it does not actually send any input to the controller. How do you fix this?
Augustine Park - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 36
Últimos 30 Días: 163
Todo El Tiempo: 7,709
