Introducción
The power switch is located on right side of the Game Boy Advance SP's button panel. It is a grey switch that dictates whether the device is powered on or powered off.
Use a standard Phillips #00 screwdriver to loosen the 4mm screw that keeps the battery cover attached to the device.
  • Use a standard Phillips #00 screwdriver to loosen the 4mm screw that keeps the battery cover attached to the device.
Agregar Comentario
Lift the battery cover up and remove it from the device.
  • Lift the battery cover up and remove it from the device.
  • The screw will remain attached to the battery cover because of Nintendo's design.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use your fingers or a plastic opening tool to remove the battery from the device.
  • Use your fingers or a plastic opening tool to remove the battery from the device.
Agregar Comentario
Using the tri-wing screwdriver, unscrew the screws holding the back cover to the device. The six screws that need to be removed include: Four #00 6.45mm tri-wing screws that are located at the corners of the device.
  • Using the tri-wing screwdriver, unscrew the screws holding the back cover to the device. The six screws that need to be removed include:
    • Four #00 6.45mm tri-wing screws that are located at the corners of the device.
    • Two #00 4.6mm tri-wing screws that are located at the top-center and bottom-center of the device.
Agregar Comentario
Lift the back cover off of the device.
  • Lift the back cover off of the device.
Agregar Comentario
Locate the power switch. Using your fingers, lift the power switch from the left side of the Game Boy Advance SP.
  • Locate the power switch.
  • Using your fingers, lift the power switch from the left side of the Game Boy Advance SP.
Agregar Comentario
Conclusión
5 personas más completaron esta guía.
DJ Pantone
Miembro Desde 11/01/13
1,012 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 17-22, Forte Winter 2013 Miembro de Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Miembros
16 Guías creadas
This doesn't explain anything about how to replace the switch
Michael - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 16
Últimos 30 Días: 105
Todo El Tiempo: 8,109
