Introducción
Regain power over your DSi XL by replacing or cleaning a faulty or sticky power button.
Remove the two Phillips screws securing the battery cover to the back of the handheld console. Lift the battery cover off the back of the DSi XL.
  • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
  • Lift the battery cover off the back of the DSi XL.
Agregar Comentario
Lift the battery from the DSi XL.
  • Lift the battery from the DSi XL.
Agregar Comentario
Remove the four rubber screw covers on the lower case by prying them up with a push pin. Remove the four rubber screw covers on the lower case by prying them up with a push pin. Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
Agregar Comentario
Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
  • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Turn the DSi XL over, and open the display. Insert a spudger between the upper and lower case at the bottom left corner of the DSi. Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  • Turn the DSi XL over, and open the display.
  • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
  • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
Agregar Comentario
Close the display and turn the DSi XL over. Lift the lower case from the front edge.
  • Close the display and turn the DSi XL over.
  • Lift the lower case from the front edge.
  • Rotate the lower case away from the DSi.
  • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
Agregar Comentario
Using a spudger, pry the SD card/right shoulder button connector off its socket. Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  • Using a spudger, pry the SD card/right shoulder button connector off its socket.
  • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
Agregar Comentario
Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-pad/power button cable. With the pointed end of the spudger, pull the D-pad/power button cable from its connector on the motherboard.
  • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-pad/power button cable.
  • With the pointed end of the spudger, pull the D-pad/power button cable from its connector on the motherboard.
Agregar Comentario
Using the flat end of the spudger, carefully pry the battery cable out of its socket on the motherboard.
  • Using the flat end of the spudger, carefully pry the battery cable out of its socket on the motherboard.
    • Use caution, as the wires are very fragile and could come out of the connector if pulled on too hard.
Agregar Comentario
Remove the seven 2.5 mm silver screws securing the power board to the upper case. Lift the power board off the upper case.
  • Remove the seven 2.5 mm silver screws securing the power board to the upper case.
  • Lift the power board off the upper case.
Agregar Comentario
Lift the rubber pad off the back of the power button. Open the display slightly and push the power button up through the upper case.
  • Lift the rubber pad off the back of the power button.
  • Open the display slightly and push the power button up through the upper case.
  • Remove the power button from the handheld console.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Brett Hartt
Miembro Desde 12/04/10
105,422 Reputación
323 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
114 Miembros
5,899 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 13
Todo El Tiempo: 6,847
