Saltar al contenido principal
Nintendo DSi Top LCD Screen Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Aviso: los pasos 1-2 provienen de una guía que está marcada como "En progreso".
    Nintendo DSi Top LCD Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Loosen the two screws on the battery panel. Then lift the panel up to remove it.
  2. Nintendo DSi Top LCD Screen Replacement: paso 2, imagen 1 de 1
    • L Button.
    • Top of the battery pack.
    • To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
  3. Aviso: los pasos 3-4 provienen de una guía que está marcada como "En progreso".
    Nintendo DSi Top LCD Screen Replacement, Motherboard: paso 3, imagen 1 de 2 Nintendo DSi Top LCD Screen Replacement, Motherboard: paso 3, imagen 2 de 2
    • Remove 4 Phillips screws from the board.
    • Lift the main board from the bottom end and flip it over to reveal the last connector.
    • Keep the main board fairly close to the case, making sure not to damage the last ribbon cable holding it in place.
  4. Nintendo DSi Top LCD Screen Replacement: paso 4, imagen 1 de 1
    • Disconnect the ribbon cable by gently using a plastic opening tool to flip up the black connector latch. The cable should easily slide out from the connector.
    • The motherboard should now be free from the rest of the device.
  5. Aviso: los pasos 5-7 provienen de una guía que está marcada como "En progreso".
    Nintendo DSi Top LCD Screen Replacement, Disassembling Nintendo DSi Bottom case: paso 5, imagen 1 de 1
    • Remove the rubber front-panel button membranes from the device. Pay careful attention to where the buttons go, so you can replace them correctly.
    • A/B/X/Y button assembly
    • Select/Start button assembly
    • D-pad
    • Power button
  6. Nintendo DSi Top LCD Screen Replacement: paso 6, imagen 1 de 2 Nintendo DSi Top LCD Screen Replacement: paso 6, imagen 2 de 2
    • Remove the plastic buttons and keep them in a safe place.
    • All of the buttons have "key" notches to prevent them from being inserted incorrectly (backwards or in the wrong place), but it can take a while to figure out where everything goes if they get shuffled around.
  7. Nintendo DSi Top LCD Screen Replacement: paso 7, imagen 1 de 2 Nintendo DSi Top LCD Screen Replacement: paso 7, imagen 2 de 2
    • Flip the case open, and push the lower screen assembly out of the frame.
  8. Nintendo DSi Top LCD Screen Replacement, Top LCD Screen: paso 8, imagen 1 de 1
    • To make the repair easier, we recommend removing the bottom LCD screen prior to replacing the top LCD screen.
    • Using a spudger, or similar tool, pry out the 4 square screw covers.
  9. Nintendo DSi Top LCD Screen Replacement: paso 9, imagen 1 de 1
    • Remove 4 Phillips screws with a #00 Phillips screwdriver.
  10. Nintendo DSi Top LCD Screen Replacement: paso 10, imagen 1 de 1
    • Place a plastic opening tool between the front panel and top edge of the outer case. Slide the tool along the edge as needed to prop open the case.
    • With the screen facing you, slide the screen side down with your thumbs to separate the screen from the cover.
  11. Nintendo DSi Top LCD Screen Replacement: paso 11, imagen 1 de 1
    • Remove the antenna from the bottom left of the device.
    • Remove the microphone from the top of the frame.
  12. Nintendo DSi Top LCD Screen Replacement: paso 12, imagen 1 de 1
    • Use a spudger to pry the camera out of its place.
  13. Nintendo DSi Top LCD Screen Replacement: paso 13, imagen 1 de 1
    • Cables for the components in the upper half of the device run through the hinge, which must be carefully disassembled before continuing.
    • Start by pushing the sliding shaft in the hinge on the opposite side of the wires/ribbons.
  14. Nintendo DSi Top LCD Screen Replacement: paso 14, imagen 1 de 1
    • On the reverse side of the casing, insert the spudger onto the surface of the sliding shaft just left of the LED light channels.
    • Push the sliding shaft completely through the hinge until it stops and the hinge is released.
  15. Nintendo DSi Top LCD Screen Replacement: paso 15, imagen 1 de 1
    • The right side of bottom case should separate from the top case when you remove the sliding shaft.
    • Do not pull up too far or the wire hinge may be damaged.
    • Slide the top case to the right to separate the joint.
    • Weave the wires and ribbons through the wire hinge to completely separate the top and bottom casings.
  16. Nintendo DSi Top LCD Screen Replacement: paso 16, imagen 1 de 2 Nintendo DSi Top LCD Screen Replacement: paso 16, imagen 2 de 2
    • The speakers are soldered to the ribbon cable attached to the upper LCD, so they must be removed at the same time as the LCD.
    • Lift the top LCD out of the plastic frame. Carefully thread the ribbon cable out of the hinge to avoid damaging it.
  17. Nintendo DSi Top LCD Screen Replacement: paso 17, imagen 1 de 1
    • To remove the speakers, place a flat object underneath and gently pry them off.
Conclusión
Una persona más ha completado esta guía.
rjcamero
Miembro Desde 11/05/09
50 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 6-1, Maness Fall 2009 Miembro de Cal Poly, Team 6-1, Maness Fall 2009
CPSU-MANESS-F09S6G1
5 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 15
Ultimos 7 días: 87
Ultimos 30 días: 358
Todo El Tiempo: 29,031
