Introducción
This guide will show how to replace the Nintendo 64 motherboard.
Remove the expansion pack cover by pushing in the tab and pulling out.
  • Remove the expansion pack cover by pushing in the tab and pulling out.
Agregar Comentario
Lever the expansion pack out using the metal spudger.
  • Lever the expansion pack out using the metal spudger.
  • A small spoon can be used in place of a spudger.
Agregar Comentario
Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
Agregar Comentario
Remove the two front feet of the N64.
  • Remove the two front feet of the N64.
Agregar Comentario
Rotate to top side up and lift off top cover.
  • Rotate to top side up and lift off top cover.
Agregar Comentario
Remove the fourteen screws indicated in the example using the larger Phillips screwdriver. Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
  • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
I’m not entirely certain if it's a common difference, but my nintendo 64 doesn’t have fourteen screws, but rather, 8 screws, and instead of 3 heat sinks, it only has the one separate heat sink on the chip close to the memory expansion pack. additionally, aside from the 6 screws closest to the expansion pack, the two other screws are held on by nuts under the metal piece.
Avery Duncan - Contestar
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the metal plate indicated in the example by sliding it back and then lifting it up. Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
Agregar Comentario
Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
Agregar Comentario
Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
Agregar Comentario
Remove the small metal bracket from the back of the expansion pack slot.
  • Remove the small metal bracket from the back of the expansion pack slot.
Agregar Comentario
Remove the small metal bracket from the front of the expansion pack slot with the metal spudger. Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
Agregar Comentario
Remove the small metal bracket behind the expansion slot using the spudger. Remove the small metal bracket behind the expansion slot using the spudger.
  • Remove the small metal bracket behind the expansion slot using the spudger.
Agregar Comentario
Remove the seven screws indicated in the example using the larger Phillips screwdriver. Remove the seven screws indicated in the example using the larger Phillips screwdriver.
  • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
Agregar Comentario
Lift off and remove the metal plate as indicated in the example.
  • Lift off and remove the metal plate as indicated in the example.
Agregar Comentario
Remove the four screws indicated using the #1 Phillips screwdriver.
  • Remove the four screws indicated using the #1 Phillips screwdriver.
Agregar Comentario
Lift up and remove the motherboard.
  • Lift up and remove the motherboard.
Agregar Comentario
Conclusión
22 personas más completaron esta guía.
tonymag28
Miembro Desde 28/10/09
1,575 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-4, Regan Fall 2009 Miembro de Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
7 Miembros
6 Guías creadas
4.2mm doesn't seem right. When I looked to purchase all I saw was 4.5mm and now that I have one in my hand it seems to fit very precisely on the screws on my N64.
negroslim - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 41
Últimos 30 Días: 203
Todo El Tiempo: 42,746
