Introducción
If you are having trouble mounting the lens and you are sure you have the correct lens type (see the camera manual for types of lenses that can be used), then use this guide to assist with replacing the lens mount.
Partes
No se requieren partes.
Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
  • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove lens mount from the camera.
  • Remove lens mount from the camera.
  • Be careful not to lose any of the three loose pieces that are under the lens mount.
Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 25-26, Garner Spring 2011 Miembro de Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 18
Todo El Tiempo: 4,266
