Introducción
The communication board sends information about the aperture and focus of the lens. If you are having trouble with focus or aperture, then there may be a problem with the communication board.
Partes
No se requieren partes.
Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
  • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
Agregar Comentario
Remove lens mount from the camera.
  • Remove lens mount from the camera.
  • Be careful not to lose any of the three loose pieces that are under the lens mount.
Agregar Comentario
Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
  • Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
  • Make sure you remember the orientation of the metal ring so that it is easier to put back in the device later.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use 00 Phillips head screwdriver to remove the screw from the bottom of the front black case.
  • Use 00 Phillips head screwdriver to remove the screw from the bottom of the front black case.
Agregar Comentario
Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all). Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all). Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all).
  • Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all).
Agregar Comentario
Remove the front case from the camera.
  • Remove the front case from the camera.
  • There is a black plastic ring in the case. Be sure not to remove it, as it can be difficult to put back.
Agregar Comentario
Use a 00 Phillips head screwdriver to remove the screws from either side of the communication board.
  • Use a 00 Phillips head screwdriver to remove the screws from either side of the communication board.
Agregar Comentario
Desolder the wires and remove them from the communication board.
  • Desolder the wires and remove them from the communication board.
  • Note: If you are unfamiliar with soldering techniques, click here for a guide.
Agregar Comentario
Conclusión
5 personas más completaron esta guía.
Equipo
Cal Poly, Team 25-26, Garner Spring 2011 Miembro de Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 4
Últimos 30 Días: 14
Todo El Tiempo: 3,978
