Saltar al contenido principal
Nikon D3200 Memory Card Replacement
  1. Nikon D3200 Memory Card Replacement, Memory Card: paso 1, imagen 1 de 1
    • Locate the memory card compartment on the right side of the LCD screen.
  2. Nikon D3200 Memory Card Replacement: paso 2, imagen 1 de 3 Nikon D3200 Memory Card Replacement: paso 2, imagen 2 de 3 Nikon D3200 Memory Card Replacement: paso 2, imagen 3 de 3
    • Gently press and slide the grooved compartment door to the left.
    • Let go of the compartment door and it will swing open.
    • Insert the memory card imitating the diagram pictured outside the compartment door.
    • Make sure to push down once the memory card is inserted to lock it in place.
Conclusión
11 personas más completaron esta guía.
Irene Huang
Miembro Desde 09/08/14
681 Reputación
3 Guías creadas
Equipo
CSU Fullerton, Team 1-3, Bruce Fall 2014 Miembro de CSU Fullerton, Team 1-3, Bruce Fall 2014
CSUF-BRUCE-F14S1G3
6 Miembros
4 Guías creadas
Un comentario
Hello is this about replacing the memory card compartment or just the memory card? Apparently the memory card compartment is not maintining the memory, it’s not keeping it in the memor slot keeps popping back up. How do I fix this? Can I replace the housing?
Joseph Antonio - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 43
Todo El Tiempo: 4,530
