Introducción
You will need a #00 phillip's head screwdriver and a black spudger (or equivalent tool).
Partes
No se requieren partes.
Turn over camera to find 5 apparent screws.
  • Turn over camera to find 5 apparent screws.
Agregar Comentario
Remove all 5 screws from the bottom of the camera and store them carefully.
  • Remove all 5 screws from the bottom of the camera and store them carefully.
Agregar Comentario
Open battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of orange lever. Remove this screw.
  • Open battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of orange lever. Remove this screw.
Agregar Comentario
Rotate camera to find side panel with lanyard attachment. Detach side panel by lifting bottom corner slightly with the spudger.
  • Rotate camera to find side panel with lanyard attachment. Detach side panel by lifting bottom corner slightly with the spudger.
Agregar Comentario
Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
  • Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
Agregar Comentario
With back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
  • With back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
Agregar Comentario
Find the five screws on the metal plate and remove them. One of them is in a hole in the corner of the metal plate. Also remove the screw at the bottom of the camera. Carefully lift metal plate from the right side to reveal a ribbon connected to the motherboard.
  • Find the five screws on the metal plate and remove them. One of them is in a hole in the corner of the metal plate.
  • Also remove the screw at the bottom of the camera.
  • Carefully lift metal plate from the right side to reveal a ribbon connected to the motherboard.
Agregar Comentario
Lift the white flap with the spudger to release the ribbon and remove back metal plate. Lift the white flap with the spudger to release the ribbon and remove back metal plate.
  • Lift the white flap with the spudger to release the ribbon and remove back metal plate.
Agregar Comentario
Lift the two ribbons with the spudger to disconnect the lens and pull it out. Lift the two ribbons with the spudger to disconnect the lens and pull it out. Lift the two ribbons with the spudger to disconnect the lens and pull it out.
  • Lift the two ribbons with the spudger to disconnect the lens and pull it out.
Agregar Comentario
Conclusión
Ryan
Miembro Desde 12/04/11
131 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 18-24, Garner Spring 2011 Miembro de Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 6
Todo El Tiempo: 1,027
