Introducción
This guide will tell you how to replace your motherboard
'Click' the battery door over to the side.
  • 'Click' the battery door over to the side.
Agregar Comentario
Open the battery door. Inside is the memory card and the battery.
  • Open the battery door. Inside is the memory card and the battery.
  • Click over the orange tab and take out the battery.
  • Close the battery lid by pushing it down and sliding it back.
Agregar Comentario
Remove the four screws located on bottom of camera.     (.086in screws)
  • Remove the four screws located on bottom of camera. (.086in screws)
Agregar Comentario
Remove the two screws, then remove the panel. (.113in screws) Remove the two screws, then remove the panel. (.113in screws)
  • Remove the two screws, then remove the panel. (.113in screws)
Agregar Comentario
Remove panel on right side (front view) by removing these two screws. (.196in screws) Remove single screw set underneath panel. (0.083in screw) Remove single screw set underneath panel. (0.083in screw)
  • Remove panel on right side (front view) by removing these two screws. (.196in screws)
  • Remove single screw set underneath panel. (0.083in screw)
Agregar Comentario
Remove the two screws attaching the back panel to the body on the left side. (.188in screws)
  • Remove the two screws attaching the back panel to the body on the left side. (.188in screws)
Agregar Comentario
Gently pull off back cover
  • Gently pull off back cover
Agregar Comentario
Remove the two screws holding on the back panel.  Then remove the three screws on the A/V Out tab (left side). (.188in screws) Remove tab.
  • Remove the two screws holding on the back panel. Then remove the three screws on the A/V Out tab (left side). (.188in screws)
  • Remove tab.
Agregar Comentario
Remove the two screws attaching the front panel to the body on the left side. (.18in screws)
  • Remove the two screws attaching the front panel to the body on the left side. (.18in screws)
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Flip up front panel.
  • Flip up front panel.
  • There should be wires still attaching the panel to body. DO NOT TRY TO PULL OFF COMPLETELY
Agregar Comentario
Remove three screws as shown. (Right screw:0.084in, Left screw:0.088in, Middle screw:0.114in)
  • Remove three screws as shown. (Right screw:0.084in, Left screw:0.088in, Middle screw:0.114in)
Agregar Comentario
Carefully pull orange LCD connector up and out of the port.
  • Carefully pull orange LCD connector up and out of the port.
  • Be careful to pull vertically while pushing the black tab upwards
Agregar Comentario
Remove the screw below the LCD (.124in)
  • Remove the screw below the LCD (.124in)
Agregar Comentario
Carefully pull out the plug connecting the LCD to the motherboard.
  • Carefully pull out the plug connecting the LCD to the motherboard.
Agregar Comentario
You can now remove the LCD from the camera body.
  • You can now remove the LCD from the camera body.
  • Insert new LCD and reassemble using the steps in reverse order.
Agregar Comentario
Remove the screw to the right of the flash.
  • Remove the screw to the right of the flash.
  • Remove the screw to the right of the microphone on the bottom. (0.124in)
Agregar Comentario
Remove the two screws on the right side of the camera. (0.115 in screws)
  • Remove the two screws on the right side of the camera. (0.115 in screws)
Agregar Comentario
Remove the four bottom screws. (0.116(fat head)-center screw, 0.112(skinny head)-other screws)
  • Remove the four bottom screws. (0.116(fat head)-center screw, 0.112(skinny head)-other screws)
Agregar Comentario
Remove the 7 screws from the back of the camera. (0.111 in screws)
  • Remove the 7 screws from the back of the camera. (0.111 in screws)
Agregar Comentario
Remove the plug that connects the lens to the left side of the motherboard by firmly grasping the base of the plug and pulling gently sideways away from the camera.
  • Remove the plug that connects the lens to the left side of the motherboard by firmly grasping the base of the plug and pulling gently sideways away from the camera.
Agregar Comentario
Remove the right panel.
  • Remove the right panel.
Agregar Comentario
Remove the screw from the top of the camera. (0.112 in screws)
  • Remove the screw from the top of the camera. (0.112 in screws)
Agregar Comentario
Remove the three screws from the motherboard. (0.112 in screws)
  • Remove the three screws from the motherboard. (0.112 in screws)
  • Detach the orange tab with the foam on top. It will click out of place.
Agregar Comentario
Remove the motherboard by pulling it up, out of the port.
  • Remove the motherboard by pulling it up, out of the port.
Agregar Comentario
Carefully remove the tab that connects the flash to the motherboard from the port by gently pulling connector to the right, out of its port.
  • Carefully remove the tab that connects the flash to the motherboard from the port by gently pulling connector to the right, out of its port.
  • Be careful when removing the connector.
Agregar Comentario
Remove the motherboard from camera body.
  • Remove the motherboard from camera body.
  • Replace with a new motherboard and follow the steps in reverse order to reassemble.
Agregar Comentario
Conclusión
Luke Baumann
Miembro Desde 13/04/11
121 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 8-5, Regan Spring 2011 Miembro de Cal Poly, Team 8-5, Regan Spring 2011
CPSU-REGAN-S11S8G5
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 10
Todo El Tiempo: 2,209
