Saltar al contenido principal
Nikon Coolpix P4 Battery Replacement
  1. Nikon Coolpix P4 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the camera upside down (have the side with the buttons facing away from you)
    • Look for the side with the triangle icon with three lines in it, this is the battery door. Add pressure and slide this door slightly until it clicks and pops open.
  2. Nikon Coolpix P4 Battery Replacement: paso 2, imagen 1 de 1
    • Once the door clicks, you can open it to reveal the slots holding the memory card and the battery.
    • Focusing on the larger slot, this holds the battery. Push the orange tab away from the slot, this will eject the old battery if one was previously inside.
    • Once this slot is open, you can place the new battery inside.
    • Make sure to close the orange tab to secure it in place!
Conclusión
2 personas más completaron esta guía.
Luke Baumann
Miembro Desde 04/13/11
128 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 8-5, Regan Spring 2011 Miembro de Cal Poly, Team 8-5, Regan Spring 2011
CPSU-REGAN-S11S8G5
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 2,452
