Saltar al contenido principal
Nikon Coolpix L18 Front Cover Replacement
Qué necesitas
  1. Nikon Coolpix L18 Front Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 Front Cover Replacement: paso 2, imagen 1 de 2 Nikon Coolpix L18 Front Cover Replacement: paso 2, imagen 2 de 2
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 Front Cover Replacement: paso 3, imagen 1 de 1
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 Front Cover Replacement, LCD Screen: paso 4, imagen 1 de 1
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 Front Cover Replacement: paso 5, imagen 1 de 1
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
  6. Nikon Coolpix L18 Front Cover Replacement: paso 6, imagen 1 de 1
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
  7. Nikon Coolpix L18 Front Cover Replacement, Front Cover: paso 7, imagen 1 de 1
    • Pry back the front cover of the camera starting from the right side.
Conclusión
Una persona más ha completado esta guía.
Andrea Govea
Miembro Desde 10/11/10
360 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-23, Regan Fall 2010 Miembro de Cal Poly, Team 9-23, Regan Fall 2010
CPSU-REGAN-F10S9G23
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 16
Todo El Tiempo: 3,257
