Introducción
Use this guide to replace the LCD.
Partes
No se requieren partes.
Clearly visible damage to the LCD. It did not even light up. Remove the screw from the right side. Remove the visible screw from the left side.
  • Clearly visible damage to the LCD. It did not even light up.
  • Remove the screw from the right side.
  • Remove the visible screw from the left side.
Agregar Comentario
Open the USB A/C cover, there is one more screw that needs to be removed. That is why it is important to always remove all covers... Remove the three screws from the bottom. Start splitting the case from the battery compartment. I used an opening tool, but fingernails will be sufficient as well.
  • Open the USB A/C cover, there is one more screw that needs to be removed. That is why it is important to always remove all covers...
  • Remove the three screws from the bottom.
  • Start splitting the case from the battery compartment. I used an opening tool, but fingernails will be sufficient as well.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
After the splitting of the case, the LCD is imediately visible. Lift the LCD out of the frame by using your fingernail or an opening tool. Do not remove it yet, it is still connected. Flip the black clasp up by using fingernails or the opening tool. No big force is required. Remove the old LCD.
  • After the splitting of the case, the LCD is imediately visible.
  • Lift the LCD out of the frame by using your fingernail or an opening tool. Do not remove it yet, it is still connected.
  • Flip the black clasp up by using fingernails or the opening tool. No big force is required. Remove the old LCD.
Agregar Comentario
Here is the new screen, note the blue tab. This is the screen protector, remove it after installation. Reassemble in reverse order. Hopefully your results will be the same as for me.
  • Here is the new screen, note the blue tab. This is the screen protector, remove it after installation.
  • Reassemble in reverse order. Hopefully your results will be the same as for me.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
oldturkey03
Miembro Desde 29/09/10
509,434 Reputación
118 Guías creadas
Equipo
OTS Miembro de OTS
Business
1 Miembro
118 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 4
Últimos 30 Días: 13
Todo El Tiempo: 2,230
