Introducción
This guide will walk you through the necessary steps to remove the lens peice in the Nikon Coolpix E5700.
Partes
No se requieren partes.
Use your finger tip to slide the battery release tab toward the battery symbol on the E5700. Open the battery door.
  • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
  • Open the battery door.
Agregar Comentario
Pull the battery out of the E5700.
  • Pull the battery out of the E5700.
  • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
Agregar Comentario
Turn to the bottom of the camera.
  • Turn to the bottom of the camera.
  • Remove the two Phillips screws located directly below the back monitor
Agregar Comentario
Turn the camera to the side with the memory card slot and open the compartment for the CF card. Remove the top two Phillips screws closest to the back panel.
  • Turn the camera to the side with the memory card slot and open the compartment for the CF card.
  • Remove the top two Phillips screws closest to the back panel.
Agregar Comentario
Turn to the back of the camera.
  • Turn to the back of the camera.
  • Remove the top most Phillips screw on the back panel.
Agregar Comentario
Turn to the last side of the back panel.
  • Turn to the last side of the back panel.
  • Remove the Phillips screw below the eyepiece.
  • Remove the Phillips screw located above the speaker.
Agregar Comentario
Gently begin to remove the back panel. Caution: There are two bundles of wires connecting the back panel to the camera. Be sure not to pull too hard and yank these out.
  • Gently begin to remove the back panel.
    • Caution: There are two bundles of wires connecting the back panel to the camera. Be sure not to pull too hard and yank these out.
Before pulling the panel. You MUST remove first de rubber bumper ( arrond the ocular piece ).
diego - Contestar
Now gently unplug the two wires at the bottom of the panel. Now gently unplug the two wires at the bottom of the panel.
  • Now gently unplug the two wires at the bottom of the panel.
Agregar Comentario
Finish pulling away the back panel.
  • Finish pulling away the back panel.
  • Turn the camera to its non-grip side.
  • Remove the Phillips screw located above the strap holder.
Agregar Comentario
Open the CF card slot. Remove the Phillips screw near the top of the camera.
  • Open the CF card slot.
  • Remove the Phillips screw near the top of the camera.
Agregar Comentario
Turn to the front of the camera.
  • Turn to the front of the camera.
  • Lift up the corner of the grip pad nearest to the flash bulb.
  • Remove the Phillips screw underneath the grip pad.
Agregar Comentario
Lift up the flash bulb container. Remove the two Phillips screws located near the base of the section.
  • Lift up the flash bulb container.
  • Remove the two Phillips screws located near the base of the section.
Agregar Comentario
Open the battery compartment. Remove the Phillips screw located at the bottom of the battery compartment.
  • Open the battery compartment.
  • Remove the Phillips screw located at the bottom of the battery compartment.
Agregar Comentario
Begin to lift the top cover from the rest of the camera.
  • Begin to lift the top cover from the rest of the camera.
  • Be careful when doing this because many wires are connecting the top piece to the camera. Pulling too hard may pull these wires out.
Agregar Comentario
In order to pull the top panel without removing the flash unit. You must remove the flash top cover, taking away the screw under the bulb (see image). then gently remove the plastic top cover. IMPORTANT: discharge the condenser as soon as possible (the flash wires are now exposed, and dangerous ).
  • In order to pull the top panel without removing the flash unit. You must remove the flash top cover, taking away the screw under the bulb (see image). then gently remove the plastic top cover. IMPORTANT: discharge the condenser as soon as possible (the flash wires are now exposed, and dangerous ).
Agregar Comentario
Unplug the orange ribbon wire from the back of the camera. Unplug the two blue ribbon wires from the back of the camera.
  • Unplug the orange ribbon wire from the back of the camera.
  • Unplug the two blue ribbon wires from the back of the camera.
Agregar Comentario
Remove the Phillips screws on both sides of the flash bulb mount. Remove the Phillips screws on both sides of the flash bulb mount.
  • Remove the Phillips screws on both sides of the flash bulb mount.
Agregar Comentario
Lift the top panel up and pull the flash bulb housing away from the rest of the top panel. Note: The top panel will be difficult to separate from the flash bulb housing. Place your hands as shown in the picture and push upward with your thumb while holding the flash bulb housing stationary
  • Lift the top panel up and pull the flash bulb housing away from the rest of the top panel.
  • Note: The top panel will be difficult to separate from the flash bulb housing. Place your hands as shown in the picture and push upward with your thumb while holding the flash bulb housing stationary
Agregar Comentario
Unplug the orange ribbon and the  other wires and finish carefully removing the top panel.
  • Unplug the orange ribbon and the other wires and finish carefully removing the top panel.
Agregar Comentario
Remove all four of the screws on the bottom of the camera.
  • Remove all four of the screws on the bottom of the camera.
Agregar Comentario
Remove the two Phillips screws located underneath the CF card cover.
  • Remove the two Phillips screws located underneath the CF card cover.
Agregar Comentario
Remove the two screws on the left side of the camera.
  • Remove the two screws on the left side of the camera.
Agregar Comentario
Unplug the blue and grey set of wires near the top of the grip. Unplug the blue ribbon wire located at the bottom-left side of the camera.
  • Unplug the blue and grey set of wires near the top of the grip.
  • Unplug the blue ribbon wire located at the bottom-left side of the camera.
Agregar Comentario
Remove the front cover slowly. Be sure that the front cover is not attached to anything or caught on anything when pulling it away from the rest of the camera. Be sure that the front cover is not attached to anything or caught on anything when pulling it away from the rest of the camera.
  • Remove the front cover slowly.
  • Be sure that the front cover is not attached to anything or caught on anything when pulling it away from the rest of the camera.
Agregar Comentario
Remove the four black screws at the corners of the lens housing. Remove the four black screws at the corners of the lens housing.
  • Remove the four black screws at the corners of the lens housing.
Agregar Comentario
Remove the lens case and the lens. Remove the lens case and the lens.
  • Remove the lens case and the lens.
Agregar Comentario
Conclusión
3 personas más completaron esta guía.
Kyle Sitton
Miembro Desde 17/04/11
333 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 24-58, Amido Spring 2011 Miembro de Cal Poly, Team 24-58, Amido Spring 2011
CPSU-AMIDO-S11S24G58
4 Miembros
9 Guías creadas
bonjour,
je viens vers vous pour vous demandez OU je vais trouver les pièces pour remettre en état j'ai un Nikon Coolpix 5700 il a l'écran tout noir sur l'écran tout noir juste le paramètre de l'appareille.
je n'arrive pas a trouver le pièce sur quel cite je pourrais trouvé sais pièces
je tient beaucoup a mon appareil
merci de me renseigné cordialement
rolland - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 5
Últimos 30 Días: 32
Todo El Tiempo: 5,074
