Saltar al contenido principal
Nikon Coolpix 995 Memory Card Replacement
  1. Nikon Coolpix 995 Memory Card Replacement, Memory Card: paso 1, imagen 1 de 2 Nikon Coolpix 995 Memory Card Replacement, Memory Card: paso 1, imagen 2 de 2
    • Set camera so the memory card compartment is facing you.
    • Place thumb under cover latch where it says "card", then gently lift straight upwards.
  2. Nikon Coolpix 995 Memory Card Replacement: paso 2, imagen 1 de 1
    • -Pull the memory card with your thumb gently .
  3. Nikon Coolpix 995 Memory Card Replacement: paso 3, imagen 1 de 2 Nikon Coolpix 995 Memory Card Replacement: paso 3, imagen 2 de 2
    • Be sure your memory card is facing the right direction, then gently insert it into the memory card slot.
    • After you properly reinsert the memory card, place your thumb on the top of the cover and gently press down until you hear and feel the cover click back into the closed position.
Conclusión
Una persona más ha completado esta guía.
Cory Layman
Miembro Desde 10/04/11
89 Reputación
3 Guías creadas
Equipo
UW Stout, Team 1-5, Zhou Fall 2011 Miembro de UW Stout, Team 1-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G5
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 2,282
