Introducción
Use this guide to replace the front cover.
Partes
No se requieren partes.
Remove the four 3.0mm screws on the bottom of the camera.
  • Remove the four 3.0mm screws on the bottom of the camera.
Agregar Comentario
Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
  • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
Agregar Comentario
Remove the two 3.0mm screws on the right side of the camera.
  • Remove the two 3.0mm screws on the right side of the camera.
Agregar Comentario
Carefully open the back cover. Take care as there are connectors still attached.
  • Carefully open the back cover. Take care as there are connectors still attached.
Agregar Comentario
Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
  • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
Agregar Comentario
Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
  • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
  • The back cover will be disconnected from the camera
Agregar Comentario
Be careful of metallic parts which are loose and will fall out.
  • Be careful of metallic parts which are loose and will fall out.
  • Remove the two 2.5mm screws on the bottom of the left side, after having removed the back cover.
Agregar Comentario
Agregar Comentario
Remove front cover.
  • Remove front cover.
Agregar Comentario
Conclusión
Kaky Payne
Miembro Desde 17/04/12
58 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 12-38, Regan Spring 2012 Miembro de Cal Poly, Team 12-38, Regan Spring 2012
CPSU-REGAN-S12S12G38
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 1,022
