Introducción
Replacing the lens of a Nikon Coolpix 3500
Partes
No se requieren partes.
Unlatch the battery cover. Slide the cover out and flip it open.
  • Unlatch the battery cover. Slide the cover out and flip it open.
  • Remove the battery.
  • Gently remove the battery cover.
Agregar Comentario
Remove the two 4.5 mm screws that sit next to the battery slot.
  • Remove the two 4.5 mm screws that sit next to the battery slot.
  • Remove the 3 mm screw that sits below the CF card slot.
  • Remove the 4.5 mm screw that sits above the digital I/O cover.
Agregar Comentario
Remove the two 4.5 mm screws that sit inside the battery slot.
  • Remove the two 4.5 mm screws that sit inside the battery slot.
Agregar Comentario
Remove the two 5 mm screws that sit near the camera strap eyelet.
  • Remove the two 5 mm screws that sit near the camera strap eyelet.
  • Remove the camera strap eyelet.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
  • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
Agregar Comentario
Remove the five 3.5 mm screws that sit at the bottom of the camera. Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
  • Remove the five 3.5 mm screws that sit at the bottom of the camera.
  • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
  • Do not apply too much force; two wires still connect the front cover to the logic board.
Agregar Comentario
Using a spudger, detach the white-capped wire. Using a spudger, detach the orange-capped wire and set the front cover aside.
  • Using a spudger, detach the white-capped wire.
  • Using a spudger, detach the orange-capped wire and set the front cover aside.
Agregar Comentario
Disconnect the grey-capped wire from the logic board
  • Disconnect the grey-capped wire from the logic board
  • Disconnect the blue wire attached to the green chip from the center of the logic board
Agregar Comentario
Remove the 3.5 mm screw from the logic board next to the rotating lens Invert the logic board and lens toward the orange and blue wires still connecting the logic board to the LED screen
  • Remove the 3.5 mm screw from the logic board next to the rotating lens
  • Invert the logic board and lens toward the orange and blue wires still connecting the logic board to the LED screen
Agregar Comentario
Disconnect the blue wire connecting the logic board to the LED screen Disconnect the orange wire using a spudger while pushing out horizontally
  • Disconnect the blue wire connecting the logic board to the LED screen
  • Disconnect the orange wire using a spudger while pushing out horizontally
  • Disconnect the red capped wire from the logic board
  • Lift the logic board and lens (still connected) out of the back case
Agregar Comentario
Lift up on the black covering and remove the orange wire connecting the lens to the logic board
  • Lift up on the black covering and remove the orange wire connecting the lens to the logic board
Agregar Comentario
Conclusión
Equipo
Cal Poly, Team 30-38, Garner Spring 2010 Miembro de Cal Poly, Team 30-38, Garner Spring 2010
CPSU-GARNER-S10S30G38
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,672
