Partes
No se requieren partes.
With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
Agregar Comentario
Remove the chrome side cover from the body of the camera.
  • Remove the chrome side cover from the body of the camera.
Agregar Comentario
Remove the four 3.2 mm screws on the bottom of the camera.
  • Remove the four 3.2 mm screws on the bottom of the camera.
Agregar Comentario
Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward) Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
  • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
Agregar Comentario
Gently separate the back cover from the body of the camera. The back casing will still be connected to the circuit board by a ribbon
  • Gently separate the back cover from the body of the camera.
  • The back casing will still be connected to the circuit board by a ribbon
Agregar Comentario
Use the tweezers to disconnect the ribbon from the circuit board.
  • Use the tweezers to disconnect the ribbon from the circuit board.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
Agregar Comentario
Gently separate the front cover from the body of the camera. The front casing will still be connected to the circuit board by a few wires
  • Gently separate the front cover from the body of the camera.
  • The front casing will still be connected to the circuit board by a few wires
Agregar Comentario
Remove the two 3.2 mm screws that hold the flash to the front cover.
  • Remove the two 3.2 mm screws that hold the flash to the front cover.
Agregar Comentario
Use the Spudger to remove the copper colored light bulb clip. Remove the front cover entierly from the camera body. Remove the front cover entierly from the camera body.
  • Use the Spudger to remove the copper colored light bulb clip.
  • Remove the front cover entierly from the camera body.
Agregar Comentario
From the top view of the camera, remove the one 5.8 mm screw. From the top view of the camera, remove the one 2.8 mm screw
  • From the top view of the camera, remove the one 5.8 mm screw.
  • From the top view of the camera, remove the one 2.8 mm screw
Agregar Comentario
Remove the three 3.4 mm screws from the back side of the camera.
  • Remove the three 3.4 mm screws from the back side of the camera.
Agregar Comentario
Remove the two 3.4 mm screws from the side of the camera.
  • Remove the two 3.4 mm screws from the side of the camera.
Agregar Comentario
Separate the two metal body pieces from the rest of the camera.
  • Separate the two metal body pieces from the rest of the camera.
Agregar Comentario
Gently remove the two ribbons connecting the lens to the mother board. Gently remove the two ribbons connecting the lens to the mother board.
  • Gently remove the two ribbons connecting the lens to the mother board.
Agregar Comentario
Gently separate the camera lens from the mother board. Gently separate the camera lens from the mother board.
  • Gently separate the camera lens from the mother board.
Agregar Comentario
The mother board is permanently fixed to the battery housing.
  • The mother board is permanently fixed to the battery housing.
  • Mother board cannot be taken a part any further.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
Cuesta, Team 1-6, Zipperian Fall 2011 Miembro de Cuesta, Team 1-6, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G6
2 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,100
