Introducción
If your screen has stopped working or needs to be replaced for some other reason, follow this guide to remove your current screen.
Partes
No se requieren partes.
On the bottom right of the camera, locate the battery flap switch.
  • On the bottom right of the camera, locate the battery flap switch.
Agregar Comentario
Move this switch to the right so the battery flap can flip open.
  • Move this switch to the right so the battery flap can flip open.
Agregar Comentario
Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
Agregar Comentario
Remove the three 3x3mm screws attached to the rear casing.
  • Remove the three 3x3mm screws attached to the rear casing.
Agregar Comentario
The panel can be identified by the wifi logo on its upper half on the camera's side.
  • The panel can be identified by the wifi logo on its upper half on the camera's side.
  • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
Agregar Comentario
Pry the panel off from the bottom using your fingernail.
  • Pry the panel off from the bottom using your fingernail.
Agregar Comentario
Remove the 3x2mm screw underneath the panel near the top of the camera.
  • Remove the 3x2mm screw underneath the panel near the top of the camera.
Agregar Comentario
Remove the 4x3mm on the opposite side near the selector wheel. Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  • Remove the 4x3mm on the opposite side near the selector wheel.
  • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
Agregar Comentario
Pry the back panel away from the body of the camera, using the space you just opened up. Be careful not to damage the ribbon cable on the opposite end of the camera.
  • Pry the back panel away from the body of the camera, using the space you just opened up.
  • Be careful not to damage the ribbon cable on the opposite end of the camera.
  • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
Agregar Comentario
Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables. The center connector is detached by flipping the black latch up and away from the center of the camera.
  • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
  • The center connector is detached by flipping the black latch up and away from the center of the camera.
  • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
Agregar Comentario
Pry the display from the rear casing using a spudger. Pry the display from the rear casing using a spudger.
  • Pry the display from the rear casing using a spudger.
Agregar Comentario
Conclusión
Kevin Backers
Miembro Desde 26/01/12
301 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 9-5, Regan Winter 2012 Miembro de Cal Poly, Team 9-5, Regan Winter 2012
CPSU-REGAN-W12S9G5
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 373
