Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
Agregar Comentario
Turn camera upside down so that the battery compartment is facing you.
  • Turn camera upside down so that the battery compartment is facing you.
  • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
Agregar Comentario
Rotate the camera to the opposite side where the A/V outlet is located.
  • Rotate the camera to the opposite side where the A/V outlet is located.
  • Unscrew and remove all four screws with a Phillips 00 screwdriver.
Agregar Comentario
Turn the camera so that the Wi-Fi adapter is facing you.
  • Turn the camera so that the Wi-Fi adapter is facing you.
Agregar Comentario
Using a plastic opening tool, pry the front casing of the camera. Continue this motion all around the front casing of the camera. Gently pull apart the front casing from the rest of the camera.
  • Using a plastic opening tool, pry the front casing of the camera.
  • Continue this motion all around the front casing of the camera.
  • Gently pull apart the front casing from the rest of the camera.
Agregar Comentario
Using the plastic opening tool pry the back casing of the camera.
  • Using the plastic opening tool pry the back casing of the camera.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Orange ribbon is fragile
  • Orange ribbon is fragile
  • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
Agregar Comentario
Pull down the on the black latch to carefully separate the orange ribbon from the motherboard. Pull apart the orange ribbon and front casing from the rest of the camera.
  • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
  • Pull apart the orange ribbon and front casing from the rest of the camera.
Agregar Comentario
Use plastic opening tool to carefully pry the LCD Screen from the camera. Use plastic opening tool to carefully pry the LCD Screen from the camera.
  • Use plastic opening tool to carefully pry the LCD Screen from the camera.
Agregar Comentario
Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard. Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
  • Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
Agregar Comentario
De-solder the black and red wires from the mainboard.
Agregar Comentario
Continue by removing two screws from the back of the camera body.
  • Continue by removing two screws from the back of the camera body.
Agregar Comentario
Remove the screw connecting the wifi card cover to the front of the camera.
  • Remove the screw connecting the wifi card cover to the front of the camera.
Agregar Comentario
Remove the final screw connecting the Wifi card cover to the case.
  • Remove the final screw connecting the Wifi card cover to the case.
Agregar Comentario
Gently pull the Wifi card cover off of the camera body.
  • Gently pull the Wifi card cover off of the camera body.
Agregar Comentario
Remove the screw holding the Wifi Card to the camera body.
  • Remove the screw holding the Wifi Card to the camera body.
Agregar Comentario
Gently pull the WiFi card out of the camera.
  • Gently pull the WiFi card out of the camera.
Agregar Comentario
Conclusión
Joshua Avery
Miembro Desde 23/01/12
7 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 3-28, Amido Winter 2012 Miembro de Cal Poly, Team 3-28, Amido Winter 2012
CPSU-AMIDO-W12S3G28
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 751
