Saltar al contenido principal
Nikon COOLPIX P2 Motherboard Replacement
Qué necesitas
  1. Nikon COOLPIX P2 Motherboard Replacement, Case: paso 1, imagen 1 de 1
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  2. Nikon COOLPIX P2 Motherboard Replacement: paso 2, imagen 1 de 1
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
  3. Nikon COOLPIX P2 Motherboard Replacement: paso 3, imagen 1 de 1
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
  4. Nikon COOLPIX P2 Motherboard Replacement: paso 4, imagen 1 de 1
    • Turn the camera so that the Wi-Fi adapter is facing you.
  5. Nikon COOLPIX P2 Motherboard Replacement: paso 5, imagen 1 de 3 Nikon COOLPIX P2 Motherboard Replacement: paso 5, imagen 2 de 3 Nikon COOLPIX P2 Motherboard Replacement: paso 5, imagen 3 de 3
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
  6. Nikon COOLPIX P2 Motherboard Replacement: paso 6, imagen 1 de 1
    • Using the plastic opening tool pry the back casing of the camera.
  7. Nikon COOLPIX P2 Motherboard Replacement: paso 7, imagen 1 de 1
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
  8. Nikon COOLPIX P2 Motherboard Replacement: paso 8, imagen 1 de 2 Nikon COOLPIX P2 Motherboard Replacement: paso 8, imagen 2 de 2
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
  9. Nikon COOLPIX P2 Motherboard Replacement, LCD Screen: paso 9, imagen 1 de 2 Nikon COOLPIX P2 Motherboard Replacement, LCD Screen: paso 9, imagen 2 de 2
    • Use plastic opening tool to carefully pry the LCD Screen from the camera.
  10. Nikon COOLPIX P2 Motherboard Replacement: paso 10, imagen 1 de 2 Nikon COOLPIX P2 Motherboard Replacement: paso 10, imagen 2 de 2
    • Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
  11. Nikon COOLPIX P2 Motherboard Replacement: paso 11, imagen 1 de 1
  12. Nikon COOLPIX P2 Motherboard Replacement, WiFi Card: paso 12, imagen 1 de 1
    • Continue by removing two screws from the back of the camera body.
  13. Nikon COOLPIX P2 Motherboard Replacement: paso 13, imagen 1 de 1
    • Remove the screw connecting the wifi card cover to the front of the camera.
  14. Nikon COOLPIX P2 Motherboard Replacement: paso 14, imagen 1 de 1
    • Remove the final screw connecting the Wifi card cover to the case.
  15. Nikon COOLPIX P2 Motherboard Replacement: paso 15, imagen 1 de 1
    • Gently pull the Wifi card cover off of the camera body.
  16. Nikon COOLPIX P2 Motherboard Replacement: paso 16, imagen 1 de 1
    • Remove the screw holding the Wifi Card to the camera body.
  17. Nikon COOLPIX P2 Motherboard Replacement: paso 17, imagen 1 de 1
    • Gently pull the WiFi card out of the camera.
  18. Nikon COOLPIX P2 Motherboard Replacement, Motherboard: paso 18, imagen 1 de 2 Nikon COOLPIX P2 Motherboard Replacement, Motherboard: paso 18, imagen 2 de 2
    • Continue removing screws from the outside of the camera body.
    • Next pull the plastic side panel off of the camera body.
    • Be extremely careful when holding the camera around the flash capacitor (circled in green), it is probably still charged, and it is very painful if you are shocked by it.
  19. Nikon COOLPIX P2 Motherboard Replacement: paso 19, imagen 1 de 3 Nikon COOLPIX P2 Motherboard Replacement: paso 19, imagen 2 de 3 Nikon COOLPIX P2 Motherboard Replacement: paso 19, imagen 3 de 3
    • Remove the two screws connecting the strap loop to the camera body.
    • Remove the three screws from the left side of the camera body.
    • Remove the screw by the shutter button.
  20. Nikon COOLPIX P2 Motherboard Replacement: paso 20, imagen 1 de 2 Nikon COOLPIX P2 Motherboard Replacement: paso 20, imagen 2 de 2
    • Remove screws from plastic side cover.
    • Pull off plastic cover.
  21. Nikon COOLPIX P2 Motherboard Replacement: paso 21, imagen 1 de 2 Nikon COOLPIX P2 Motherboard Replacement: paso 21, imagen 2 de 2
    • Carefully remove the back housing body from the camera.
  22. Nikon COOLPIX P2 Motherboard Replacement: paso 22, imagen 1 de 2 Nikon COOLPIX P2 Motherboard Replacement: paso 22, imagen 2 de 2
    • Remove the five screws connecting motherboard to the camera body.
    • Carefully detach the two ribbon cables from the motherboard by releasing the black plastic catch, then pull the cables gently upwards out of the connector.
  23. Nikon COOLPIX P2 Motherboard Replacement: paso 23, imagen 1 de 1
    • Carefully de-solder the four connections to the motherboard.
Conclusión
Joshua Avery
Miembro Desde 01/23/12
31 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 3-28, Amido Winter 2012 Miembro de Cal Poly, Team 3-28, Amido Winter 2012
CPSU-AMIDO-W12S3G28
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 1,343
