Introducción
This guide will help you replace the rear facing camera.
Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
  • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
  • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
Agregar Comentario
Remove the rear panel from the Nexus S.
  • Remove the rear panel from the Nexus S.
Agregar Comentario
Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
  • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
  • Remove the battery from the Nexus S.
Agregar Comentario
Use your thumb to slide the SIM card downwards from the SIM card slot. Remove the SIM card.
  • Use your thumb to slide the SIM card downwards from the SIM card slot.
  • Remove the SIM card.
Agregar Comentario
Remove the six Phillips screws securing the rear inner frame to the inner case.
  • Remove the six Phillips screws securing the rear inner frame to the inner case.
Agregar Comentario
Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
  • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
  • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
Agregar Comentario
Insert the plastic opening tool to the right of the power button. Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  • Insert the plastic opening tool to the right of the power button.
  • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
Agregar Comentario
In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S. In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
Agregar Comentario
Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
Agregar Comentario
Lift and remove the rear inner frame from the Nexus S.
  • Lift and remove the rear inner frame from the Nexus S.
Agregar Comentario
Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
  • Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
Agregar Comentario
Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard. Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard. Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
  • Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
  • Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
  • Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
Agregar Comentario
Lift and remove the SIM Card board out of the Nexus S.
  • Lift and remove the SIM Card board out of the Nexus S.
Agregar Comentario
Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
  • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
Agregar Comentario
Repeat the same procedure as the previous step to disconnect the digitizer connector.
  • Repeat the same procedure as the previous step to disconnect the digitizer connector.
Agregar Comentario
Use a plastic opening tool to pry the speaker connector (highlighted in red) from its socket on the motherboard.
  • Use a plastic opening tool to pry the speaker connector (highlighted in red) from its socket on the motherboard.
  • Remove the three Phillips screws securing the motherboard to the inner assembly.
Agregar Comentario
Lift and remove the motherboard from the Nexus S, minding any cables that may get caught.
  • Lift and remove the motherboard from the Nexus S, minding any cables that may get caught.
Agregar Comentario
Use the edge of plastic opening tool to flip up the rear facing camera ZIF connector. Use the edge of plastic opening tool to flip up the rear facing camera ZIF connector.
  • Use the edge of plastic opening tool to flip up the rear facing camera ZIF connector.
Agregar Comentario
Use a pair of tweezers to lift and remove the rear camera from the motherboard.
  • Use a pair of tweezers to lift and remove the rear camera from the motherboard.
Agregar Comentario
Conclusión
6 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 2,770
