Introducción
Use this guide to replace the motherboard (includes rear camera and speaker).
Partes
No se requieren partes.
Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
  • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
  • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
Agregar Comentario
Remove the rear panel from the Nexus S.
  • Remove the rear panel from the Nexus S.
Agregar Comentario
Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
  • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
  • Remove the battery from the Nexus S.
Agregar Comentario
Use your thumb to slide the SIM card downwards from the SIM card slot. Remove the SIM card.
  • Use your thumb to slide the SIM card downwards from the SIM card slot.
  • Remove the SIM card.
Agregar Comentario
Remove the six Phillips screws securing the rear inner frame to the inner case.
  • Remove the six Phillips screws securing the rear inner frame to the inner case.
Agregar Comentario
Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
  • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
  • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
Agregar Comentario
Insert the plastic opening tool to the right of the power button. Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  • Insert the plastic opening tool to the right of the power button.
  • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
Agregar Comentario
In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S. In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
Agregar Comentario
Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
Agregar Comentario
Lift and remove the rear inner frame from the Nexus S.
  • Lift and remove the rear inner frame from the Nexus S.
Agregar Comentario
Disconnect the following cables from their respective sockets on the motherboard:
  • Disconnect the following cables from their respective sockets on the motherboard:
    • Headphone jack cable
    • Digitizer cable connector
    • Camera/SIM board connector
Agregar Comentario
Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards. Make sure to pry on the connector and not the socket itself. Prying the socket may cause severe damage. Repeat the procedure for the digitizer and rear camera/SIM board connectors.
  • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
  • Make sure to pry on the connector and not the socket itself. Prying the socket may cause severe damage.
  • Repeat the procedure for the digitizer and rear camera/SIM board connectors.
Agregar Comentario
Remove the three Phillips screws securing the motherboard to the front display assembly.
  • Remove the three Phillips screws securing the motherboard to the front display assembly.
Agregar Comentario
Wedge the plastic opening tool near the bottom right corner of the motherboard and pry upwards to dislodge it from its recess. Lift and remove the motherboard.
  • Wedge the plastic opening tool near the bottom right corner of the motherboard and pry upwards to dislodge it from its recess.
  • Lift and remove the motherboard.
Agregar Comentario
Conclusión
12 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 16
Todo El Tiempo: 12,993
