Introducción
This is a relatively easy repair to make to your Q. Follow the prerequisite for removing the inner dome daughterboard to get started.
Squeeze and pull to pop the cap off of the Nexus Q.
  • Squeeze and pull to pop the cap off of the Nexus Q.
Agregar Comentario
Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger. Once the antenna is disconnected, simply pull it off the outside of the inner dome.
  • Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger.
  • Once the antenna is disconnected, simply pull it off the outside of the inner dome.
Why remove the anntenna? what did it do to you?
rudyt83 - Contestar
Undo the ZIF connector by prying with a spudger.
  • Undo the ZIF connector by prying with a spudger.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use a T10 Torx screwdriver to remove the four 1.3 mm screws holding the inner dome in place.
  • Use a T10 Torx screwdriver to remove the four 1.3 mm screws holding the inner dome in place.
Agregar Comentario
Use a T6 Torx screwdriver to undo the three 0.8 mm screws holding the inner dome daughterboard in place.
  • Use a T6 Torx screwdriver to undo the three 0.8 mm screws holding the inner dome daughterboard in place.
Agregar Comentario
Use a spudger to disconnect the daughterboard from the ZIF connector.
  • Use a spudger to disconnect the daughterboard from the ZIF connector.
Agregar Comentario
Use a spudger to pry out the NFC antenna. The antenna has two layers; be careful not to pry the two layers apart.
  • Use a spudger to pry out the NFC antenna.
  • The antenna has two layers; be careful not to pry the two layers apart.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Alex Thomas
Miembro Desde 31/01/13
27 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 7-10, Maness Winter 2013 Miembro de Cal Poly, Team 7-10, Maness Winter 2013
CPSU-MANESS-W13S7G10
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 512
