Saltar al contenido principal
Nexus One Front Speaker Replacement
Qué necesitas
  1. Nexus One Front Speaker Replacement, Rear Cover: paso 1, imagen 1 de 2 Nexus One Front Speaker Replacement, Rear Cover: paso 1, imagen 2 de 2
    • Using two fingers, push up on the rear cover.
  2. Nexus One Front Speaker Replacement: paso 2, imagen 1 de 1
    • The rear cover slides up and off.
  3. Nexus One Front Speaker Replacement, Battery: paso 3, imagen 1 de 1
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One Front Speaker Replacement: paso 4, imagen 1 de 1
    • Pull the battery up and out.
  5. Nexus One Front Speaker Replacement, Battery Housing: paso 5, imagen 1 de 1
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One Front Speaker Replacement: paso 6, imagen 1 de 2 Nexus One Front Speaker Replacement: paso 6, imagen 2 de 2
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One Front Speaker Replacement: paso 7, imagen 1 de 2 Nexus One Front Speaker Replacement: paso 7, imagen 2 de 2
    • Pry the upper left tab open on the battery housing.
  8. Nexus One Front Speaker Replacement: paso 8, imagen 1 de 2 Nexus One Front Speaker Replacement: paso 8, imagen 2 de 2
    • Pry the top tab of the battery housing.
  9. Nexus One Front Speaker Replacement: paso 9, imagen 1 de 2 Nexus One Front Speaker Replacement: paso 9, imagen 2 de 2
    • Pry the right side tab of the battery housing.
  10. Nexus One Front Speaker Replacement: paso 10, imagen 1 de 2 Nexus One Front Speaker Replacement: paso 10, imagen 2 de 2
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One Front Speaker Replacement, Motherboards: paso 11, imagen 1 de 2 Nexus One Front Speaker Replacement, Motherboards: paso 11, imagen 2 de 2
    • Insert the spudger under the connector.
    • Push the spudger up and twist to release the connector.
    • Repeat for the next connector.
  12. Nexus One Front Speaker Replacement: paso 12, imagen 1 de 3 Nexus One Front Speaker Replacement: paso 12, imagen 2 de 3 Nexus One Front Speaker Replacement: paso 12, imagen 3 de 3
    • Push on the USB port to expose the black connector.
    • Use the spudger to pry the connector upwards.
  13. Nexus One Front Speaker Replacement: paso 13, imagen 1 de 2 Nexus One Front Speaker Replacement: paso 13, imagen 2 de 2
    • Place the spugder under the antenna connector.
    • Pry connector up vertically.
  14. Nexus One Front Speaker Replacement: paso 14, imagen 1 de 3 Nexus One Front Speaker Replacement: paso 14, imagen 2 de 3 Nexus One Front Speaker Replacement: paso 14, imagen 3 de 3
    • Insert the spudger into tab above the camera.
    • Slide upwards until the board detaches from the case.
  15. Nexus One Front Speaker Replacement: paso 15, imagen 1 de 1
    • Press the pointed tip of the spudger into the space below the button assembly.
    • Wiggle the spudger tip towards the outside of the button.
    • The button assembly is under some tension and may fly off.
  16. Nexus One Front Speaker Replacement: paso 16, imagen 1 de 1
    • Push the pointed tip of the spudger into the base of the side button board.
    • Lift up, the board will disconnect from the case.
  17. Nexus One Front Speaker Replacement: paso 17, imagen 1 de 3 Nexus One Front Speaker Replacement: paso 17, imagen 2 de 3 Nexus One Front Speaker Replacement: paso 17, imagen 3 de 3
    • Push on the lower motherboard until it slides under the case support.
    • The motherboard assembly comes out as a single piece.
    • Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
  18. Nexus One Front Speaker Replacement, Front Speaker: paso 18, imagen 1 de 1
    • Using the spudger, pop up the end of the speaker.
Conclusión
Una persona más ha completado esta guía.
Niklas Johnson
Miembro Desde 01/31/12
1,207 Reputación
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,292
