Introducción
installing the flash
Using two fingers, push up on the rear cover. Using two fingers, push up on the rear cover.
  • Using two fingers, push up on the rear cover.
Agregar Comentario
The rear cover slides up and off.
  • The rear cover slides up and off.
Agregar Comentario
Using the plastic opening tools, pry the left bottom corner of the battery up.
  • Using the plastic opening tools, pry the left bottom corner of the battery up.
Agregar Comentario
Pull the battery up and out.
  • Pull the battery up and out.
Agregar Comentario
Remove the two Torx T5 screws.
  • Remove the two Torx T5 screws.
  • Remove the one Philips #00 screw.
#0 Phillis screw
skuhry - Contestar
Using the plastic opening tool, pry up the battery housing upwards. Push pry tool down, undoing the plastic tab.
  • Using the plastic opening tool, pry up the battery housing upwards.
  • Push pry tool down, undoing the plastic tab.
Agregar Comentario
Pry the upper left tab open on the battery housing. Pry the upper left tab open on the battery housing.
  • Pry the upper left tab open on the battery housing.
Agregar Comentario
Pry the top tab of the battery housing. Pry the top tab of the battery housing.
  • Pry the top tab of the battery housing.
Agregar Comentario
Pry the right side tab of the battery housing. Pry the right side tab of the battery housing.
  • Pry the right side tab of the battery housing.
Agregar Comentario
Pull up on the battery housing. Slide the battery housing out to remove it.
  • Pull up on the battery housing.
  • Slide the battery housing out to remove it.
Agregar Comentario
Insert the spudger under the bottom of the flash board
  • Insert the spudger under the bottom of the flash board
  • Twist the spudger to lift and release the flash board.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Niklas Johnson
Miembro Desde 31/01/12
1,063 Reputación
18 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,716
