Saltar al contenido principal
Nexus One Camera Replacement
Qué necesitas
  1. Nexus One Camera Replacement, Rear Cover: paso 1, imagen 1 de 2 Nexus One Camera Replacement, Rear Cover: paso 1, imagen 2 de 2
    • Using two fingers, push up on the rear cover.
  2. Nexus One Camera Replacement: paso 2, imagen 1 de 1
    • The rear cover slides up and off.
  3. Nexus One Camera Replacement, Battery: paso 3, imagen 1 de 1
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One Camera Replacement: paso 4, imagen 1 de 1
    • Pull the battery up and out.
  5. Nexus One Camera Replacement, Battery Housing: paso 5, imagen 1 de 1
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One Camera Replacement: paso 6, imagen 1 de 2 Nexus One Camera Replacement: paso 6, imagen 2 de 2
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One Camera Replacement: paso 7, imagen 1 de 2 Nexus One Camera Replacement: paso 7, imagen 2 de 2
    • Pry the upper left tab open on the battery housing.
  8. Nexus One Camera Replacement: paso 8, imagen 1 de 2 Nexus One Camera Replacement: paso 8, imagen 2 de 2
    • Pry the top tab of the battery housing.
  9. Nexus One Camera Replacement: paso 9, imagen 1 de 2 Nexus One Camera Replacement: paso 9, imagen 2 de 2
    • Pry the right side tab of the battery housing.
  10. Nexus One Camera Replacement: paso 10, imagen 1 de 2 Nexus One Camera Replacement: paso 10, imagen 2 de 2
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One Camera Replacement, Camera: paso 11, imagen 1 de 3 Nexus One Camera Replacement, Camera: paso 11, imagen 2 de 3 Nexus One Camera Replacement, Camera: paso 11, imagen 3 de 3
    • Place the spudger under the metal cover and pry upwards. (shoot bottom side first with tabbed clip)
    • Swap the spudger to the other side of the cover base. Pry upwards. (fix?)
    • Grasp the camera module and pull up.
Conclusión
Una persona más ha completado esta guía.
Niklas Johnson
Miembro Desde 01/31/12
1,207 Reputación
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,498
