Saltar al contenido principal
Nexus 10 Headphone Jack Replacement
Qué necesitas
  1. Nexus 10 Headphone Jack Replacement, Battery: paso 1, imagen 1 de 3 Nexus 10 Headphone Jack Replacement, Battery: paso 1, imagen 2 de 3 Nexus 10 Headphone Jack Replacement, Battery: paso 1, imagen 3 de 3
    • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
  2. Nexus 10 Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
  3. Nexus 10 Headphone Jack Replacement: paso 3, imagen 1 de 3 Nexus 10 Headphone Jack Replacement: paso 3, imagen 2 de 3 Nexus 10 Headphone Jack Replacement: paso 3, imagen 3 de 3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  4. Nexus 10 Headphone Jack Replacement: paso 4, imagen 1 de 3 Nexus 10 Headphone Jack Replacement: paso 4, imagen 2 de 3 Nexus 10 Headphone Jack Replacement: paso 4, imagen 3 de 3
    • Detach the three connector ribbons passing over the battery using the plastic opening tool.
  5. Nexus 10 Headphone Jack Replacement: paso 5, imagen 1 de 1
    • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
  6. Nexus 10 Headphone Jack Replacement: paso 6, imagen 1 de 2 Nexus 10 Headphone Jack Replacement: paso 6, imagen 2 de 2
    • Disconnect the battery by lifting it upward and pulling it away from the connector.
  7. Nexus 10 Headphone Jack Replacement, Headphone Jack: paso 7, imagen 1 de 1
    • Remove one screw on the logic board with a PH00 screwdriver.
  8. Nexus 10 Headphone Jack Replacement: paso 8, imagen 1 de 3 Nexus 10 Headphone Jack Replacement: paso 8, imagen 2 de 3 Nexus 10 Headphone Jack Replacement: paso 8, imagen 3 de 3
    • Disconnect right speaker connector ribbon from logic board.
    • Lift the speaker out by pulling up on its corner.
  9. Nexus 10 Headphone Jack Replacement: paso 9, imagen 1 de 3 Nexus 10 Headphone Jack Replacement: paso 9, imagen 2 de 3 Nexus 10 Headphone Jack Replacement: paso 9, imagen 3 de 3
    • Disconnect connectors around the perimeter of the motherboard.
  10. Nexus 10 Headphone Jack Replacement: paso 10, imagen 1 de 2 Nexus 10 Headphone Jack Replacement: paso 10, imagen 2 de 2
    • Remove motherboard by gently pulling upward under its corner.
  11. Nexus 10 Headphone Jack Replacement: paso 11, imagen 1 de 1
    • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
  12. Nexus 10 Headphone Jack Replacement: paso 12, imagen 1 de 2 Nexus 10 Headphone Jack Replacement: paso 12, imagen 2 de 2
    • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
  13. Nexus 10 Headphone Jack Replacement: paso 13, imagen 1 de 2 Nexus 10 Headphone Jack Replacement: paso 13, imagen 2 de 2
    • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
  14. Nexus 10 Headphone Jack Replacement: paso 14, imagen 1 de 2 Nexus 10 Headphone Jack Replacement: paso 14, imagen 2 de 2
    • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
Conclusión
Benjamin Troller
Miembro Desde 04/11/16
2,181 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 34-18, Maness Spring 2016 Miembro de Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 14
Todo El Tiempo: 732
