Saltar al contenido principal
Nexus 10 Front Facing Camera Replacement
Qué necesitas
  1. Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: paso 1, imagen 1 de 3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: paso 1, imagen 2 de 3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: paso 1, imagen 3 de 3
    • Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back.
  2. Nexus 10 Front Facing Camera Replacement: paso 2, imagen 1 de 3 Nexus 10 Front Facing Camera Replacement: paso 2, imagen 2 de 3 Nexus 10 Front Facing Camera Replacement: paso 2, imagen 3 de 3
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  3. Nexus 10 Front Facing Camera Replacement: paso 3, imagen 1 de 3 Nexus 10 Front Facing Camera Replacement: paso 3, imagen 2 de 3 Nexus 10 Front Facing Camera Replacement: paso 3, imagen 3 de 3
    • Lift latch on front-facing camera connector.
    • Pull the connector toward the top of the device and remove the front-facing camera.
Conclusión
Benjamin Troller
Miembro Desde 04/11/16
2,181 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 34-18, Maness Spring 2016 Miembro de Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 578
