Introducción
By removing the case you will be able to install a capacitor or an antenna.
Partes
No se requieren partes.
Rotate the device so that the bottom is facing up.
  • Rotate the device so that the bottom is facing up.
Agregar Comentario
Lift up all four rubber pads on the bottom of the router with the plastic opening tool. Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
  • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
Agregar Comentario
Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router. Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
Agregar Comentario
Lift the bottom casing straight up from the router.
  • Lift the bottom casing straight up from the router.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Ryan Murphy
Miembro Desde 03/10/11
482 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 21-24, Maness Fall 2011 Miembro de Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 4
Todo El Tiempo: 1,178
