Introducción
This guide will take you through the process involved with removing a capacitor. De-soldering and soldering will be required.
Rotate the device so that the bottom is facing up.
  • Rotate the device so that the bottom is facing up.
Agregar Comentario
Lift up all four rubber pads on the bottom of the router with the plastic opening tool. Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
  • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
Agregar Comentario
Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router. Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
Agregar Comentario
Lift the bottom casing straight up from the router.
  • Lift the bottom casing straight up from the router.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Remove the clear plastic casing by lifting it straight up from the router.
  • Remove the clear plastic casing by lifting it straight up from the router.
Agregar Comentario
Separate the motherboard from the top shell by lifting it straight up from the router. Separate the motherboard from the top shell by lifting it straight up from the router.
  • Separate the motherboard from the top shell by lifting it straight up from the router.
Agregar Comentario
Rotate the motherboard so that the top is facing up. Set the motherboard on a flat clean surface.
  • Rotate the motherboard so that the top is facing up.
  • Set the motherboard on a flat clean surface.
Agregar Comentario
The capacitor can be found at the location shown. The capacitor can be found at the location shown.
  • The capacitor can be found at the location shown.
Agregar Comentario
Rotate the motherboard so that the bottom is facing up. Locate the two soldered contacts of the capacitor.
  • Rotate the motherboard so that the bottom is facing up.
  • Locate the two soldered contacts of the capacitor.
Agregar Comentario
Rotate the motherboard 180 degrees. Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only. Refer to this link for proper de-soldering and soldering techniques.
  • Rotate the motherboard 180 degrees.
  • Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only.
  • Refer to this link for proper de-soldering and soldering techniques.
  • Pull the capacitor from the other side of the circuit board once the solder is liquified.
  • To replace the capacitor, orient the negative side of the capacitor (indicated by a white stripe and a negative sign) so that it aligns with the shaded white region of the circle indicating the capacitor's position on the motherboard.
Agregar Comentario
Conclusión
Kyle Moore
Miembro Desde 03/10/11
74 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 21-24, Maness Fall 2011 Miembro de Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Miembros
6 Guías creadas
looks like that's a 220microF at 25V right ?
probably better to replace it with a similar 220microF, but with higher voltage rating.
email_etran - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 2,680
