Saltar al contenido principal
Nerf N-Strike Firestrike O-Ring and Plunger Replacement
Qué necesitas
  1. Nerf N-Strike Firestrike O-Ring and Plunger Replacement, Remove battery cover: paso 1, imagen 1 de 1
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Nerf N-Strike Firestrike O-Ring and Plunger Replacement: paso 2, imagen 1 de 2 Nerf N-Strike Firestrike O-Ring and Plunger Replacement: paso 2, imagen 2 de 2
    • Slide out the two AAA batteries using your fingers.
  3. Nerf N-Strike Firestrike O-Ring and Plunger Replacement, Blaster Casing: paso 3, imagen 1 de 1
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nerf N-Strike Firestrike O-Ring and Plunger Replacement: paso 4, imagen 1 de 2 Nerf N-Strike Firestrike O-Ring and Plunger Replacement: paso 4, imagen 2 de 2
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. Nerf N-Strike Firestrike O-Ring and Plunger Replacement: paso 5, imagen 1 de 2 Nerf N-Strike Firestrike O-Ring and Plunger Replacement: paso 5, imagen 2 de 2
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Nerf N-Strike Firestrike O-Ring and Plunger Replacement, O-Ring and Plunger: paso 6, imagen 1 de 3 Nerf N-Strike Firestrike O-Ring and Plunger Replacement, O-Ring and Plunger: paso 6, imagen 2 de 3 Nerf N-Strike Firestrike O-Ring and Plunger Replacement, O-Ring and Plunger: paso 6, imagen 3 de 3
    • Without removing the barrel assembly, tilt it slightly upwards.
    • Slide the plunger out from the air chamber.
Conclusión
3 personas más completaron esta guía.
Clovis Jahan
Miembro Desde 04/23/15
200 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-6, Amido Spring 2015 Miembro de Cal Poly, Team 15-6, Amido Spring 2015
CPSU-AMIDO-S15S15G6
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 18
Todo El Tiempo: 4,655
