Introducción
Removing the lower case allows you to replace the hardware inside the device.
Partes
No se requieren partes.
Turn the device so that the bottom is facing up.
  • Turn the device so that the bottom is facing up.
Agregar Comentario
Use the plastic opening tool to carefully lift the rubber stops in each corner. Do not completely remove the rubber stops, because they are difficult to replace. Do not completely remove the rubber stops, because they are difficult to replace.
  • Use the plastic opening tool to carefully lift the rubber stops in each corner.
  • Do not completely remove the rubber stops, because they are difficult to replace.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device. Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
  • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
Agregar Comentario
Lift the lower case straight up from the rest of the router. Lift the lower case straight up from the rest of the router.
  • Lift the lower case straight up from the rest of the router.
Agregar Comentario
Conclusión
Nicole Slagle
Miembro Desde 25/01/13
77 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 3-31, Amido Winter 2013 Miembro de Cal Poly, Team 3-31, Amido Winter 2013
CPSU-AMIDO-W13S3G31
3 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 6
Todo El Tiempo: 312
