Introducción
This guide will demonstrate how to remove the capacitors in order to replace them. Soldering and de-soldering will be required.
Turn the device so that the bottom is facing up.
  • Turn the device so that the bottom is facing up.
Agregar Comentario
Use the plastic opening tool to carefully lift the rubber stops in each corner. Do not completely remove the rubber stops, because they are difficult to replace. Do not completely remove the rubber stops, because they are difficult to replace.
  • Use the plastic opening tool to carefully lift the rubber stops in each corner.
  • Do not completely remove the rubber stops, because they are difficult to replace.
Agregar Comentario
Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device. Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
  • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
Agregar Comentario
Lift the lower case straight up from the rest of the router. Lift the lower case straight up from the rest of the router.
  • Lift the lower case straight up from the rest of the router.
Agregar Comentario
Remove the clear plastic casing by lifting it straight up from the router. Remove the clear plastic casing by lifting it straight up from the router.
  • Remove the clear plastic casing by lifting it straight up from the router.
Agregar Comentario
Separate the motherboard from the top shell by lifting it straight up from the router. Separate the motherboard from the top shell by lifting it straight up from the router.
  • Separate the motherboard from the top shell by lifting it straight up from the router.
Agregar Comentario
Turn the motherboard so that the top is facing upwards.
  • Turn the motherboard so that the top is facing upwards.
  • Place the motherboard on a clean flat surface.
Agregar Comentario
Locate the four capacitors.
  • Locate the four capacitors.
Agregar Comentario
Turn the motherboard so that the bottom is facing upwards. Locate the two soldered contacts for each capacitor.
  • Turn the motherboard so that the bottom is facing upwards.
  • Locate the two soldered contacts for each capacitor.
Agregar Comentario
Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes. Desolder the soldered connections between the capacitors and the motherboard, and pull the capacitor from the motherboard.
  • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
  • Desolder the soldered connections between the capacitors and the motherboard, and pull the capacitor from the motherboard.
  • For proper soldering and de-soldering techniques, refer here.
  • When reinstalling the capacitor, make sure the negative side of the capacitor is aligned with the shaded white region of the circle.
Agregar Comentario
Conclusión
Jonathon Sather
Miembro Desde 23/01/13
27 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 3-31, Amido Winter 2013 Miembro de Cal Poly, Team 3-31, Amido Winter 2013
CPSU-AMIDO-W13S3G31
3 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 8
Todo El Tiempo: 1,019
