Introducción
Today we are going to repair the speaker system in the phone. This may be due to simple wire disconnections and may require soldering or a replacement of the system.
Partes
No se requieren partes.
Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it. Slide the notch downward while pulling the back cover off to remove it.
  • Slide the notch downward while pulling the back cover off to remove it.
Agregar Comentario
Use your fingers to push the battery upward from the bottom. Lift upwards to remove the battery. Lift upwards to remove the battery.
  • Use your fingers to push the battery upward from the bottom.
  • Lift upwards to remove the battery.
Agregar Comentario
Unscrew the antenna in a counter-clockwise fashion. Remove the aluminum cover.
  • Unscrew the antenna in a counter-clockwise fashion.
  • Remove the aluminum cover.
Agregar Comentario
Unscrew the 3 screws shown. Lift up the right part of the Nextel logo and unscrew the screw underneath. Lift up the right part of the Nextel logo and unscrew the screw underneath.
  • Unscrew the 3 screws shown.
  • Lift up the right part of the Nextel logo and unscrew the screw underneath.
Agregar Comentario
DO NOT force the cover off as it could damage the ribbon cable! Gently lift the back cover off.
  • DO NOT force the cover off as it could damage the ribbon cable!
  • Gently lift the back cover off.
Agregar Comentario
Carefully pry off the connection between the headphone jack and logic board. Carefully pry off the connection between the headphone jack and logic board. Carefully pry off the connection between the headphone jack and logic board.
  • Carefully pry off the connection between the headphone jack and logic board.
Agregar Comentario
Use the prying tools to wedge out the circular part of the speaker system. Carefully pull out the wiring and circuit board attached to the speaker system using a prying tool or tweezers. Carefully pull out the wiring and circuit board attached to the speaker system using a prying tool or tweezers.
  • Use the prying tools to wedge out the circular part of the speaker system.
  • Carefully pull out the wiring and circuit board attached to the speaker system using a prying tool or tweezers.
Agregar Comentario
Conclusión
Jorge
Miembro Desde 14/04/10
4 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 29-61, Johann Spring 2010 Miembro de Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,122
