Saltar al contenido principal
Motorola i850 Speaker Replacement
Qué necesitas
  1. Motorola i850 Speaker Replacement, LCD Board: paso 1, imagen 1 de 1
    • Open the flip cover of the phone with the LCD screen facing towards you.
  2. Motorola i850 Speaker Replacement: paso 2, imagen 1 de 2 Motorola i850 Speaker Replacement: paso 2, imagen 2 de 2
    • Use a Razor Blade to remove the screw covers.
    • Razor Blade is very sharp. Use caution.
  3. Motorola i850 Speaker Replacement: paso 3, imagen 1 de 1
    • Unscrew the screws using a Phillips #00 Screwdriver.
  4. Motorola i850 Speaker Replacement: paso 4, imagen 1 de 1
    • Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
  5. Motorola i850 Speaker Replacement: paso 5, imagen 1 de 1
    • Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
  6. Motorola i850 Speaker Replacement: paso 6, imagen 1 de 1
    • Partially close the flip cover of the phone in order to take off the outer case.
  7. Motorola i850 Speaker Replacement: paso 7, imagen 1 de 1
    • Completely remove the outer casing from the phone.
  8. Motorola i850 Speaker Replacement: paso 8, imagen 1 de 2 Motorola i850 Speaker Replacement: paso 8, imagen 2 de 2
    • Place your thumb underneath the protective metal covering to remove it from the phone.
  9. Motorola i850 Speaker Replacement: paso 9, imagen 1 de 1
    • Gently detach the black microchip from the phone with a Tweezer.
  10. Motorola i850 Speaker Replacement: paso 10, imagen 1 de 1
    • Prop out the LCD board from the phone using your fingertips.
  11. Motorola i850 Speaker Replacement: paso 11, imagen 1 de 2 Motorola i850 Speaker Replacement: paso 11, imagen 2 de 2
    • Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
  12. Motorola i850 Speaker Replacement, Speaker: paso 12, imagen 1 de 1
    • Use a flathead screwdriver to gently remove the speaker.
  13. Motorola i850 Speaker Replacement: paso 13, imagen 1 de 1
    • Insert the new speaker into the phone and it should look like the image at left.
Conclusión
Kevin Dermody
Miembro Desde 04/08/10
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 34-56, Forte Spring 2010 Miembro de Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 1,158
